Hi Guys,
I have a windscreen surround with good glass, no rust holes of a LJ50 soft top.
Also still has the wipers and wipermotor attached.
It has some minor dents on the seam (easily covered if you put the seam rubber/plastic stuff around the frame)
Also some surface rusting here and there, but no holes.
I want to swap for a similar condition complete LJ80 one.
Thats weird. I just checked and I have two other LJ80s here and one has 2 hole and the other has 3.. But the strange thing is that BOTH screens are tapered at the top.
The LJ50 screen i want to swap is basically a rectangle, it doesn't taper at the top. also.. I bought it from a guy who was wrecking his LJ50..
Will have a better look tomorrow in daylight.
BTW it has the hinges fitted.
Users browsing this forum: No registered users and 57 guests
