It is currently Thu Oct 15, 2026 6:42 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Post Posted: Sat Dec 31, 2011 1:36 am
All sold
:woohoo: photo for some of the parts are here http://s1199.photobucket.com/albums/aa4 ... 1QQtppZZ24
NT rear axles with new wheel bearings and brake drum assembly with new brake pads, missing the one master cylinder need them gone as one whole piece as I don’t want the bearings to get wrecked by water damage. Make offers.$65
repco rear diff seals new $10 for the pair
monza window winder used $15 for the pair
3x hardtop side windows $10
Rear Window with rubber for hard top rear door without demister good for when doing ute conversion $10
NT seat mounts the ones that fold forwards good for utes x2 $10each
Pedal box $5
toyota 4y carbys x2 off a toyota hilux 1985 they well need a good clean and a carby kit put in them $50ono for both of them
Yamaha yz125h 1981 first of the water cooled 125cc $1200ono
4ft fish tank used as a reptile cage $60
alot of baby stuff will list soon
suzuki sierra
1L bonnet with a hole cut into it $5
2x rear hard top door hinges $5
2x Behind steering wheel cover $5 each
3x front indicator brackets $2
3x side indicator brackets $free
1x reverse light cover $2
2x brake light and indicator covers $free
1x side indicator cover $3 sold pending payment
2x bonnet releases cable $5
Driver’s seat rails $10
1x brand new door handle $15
1x brand new window winder $5
Hard top roof head liner bar $2
handbrake leaver $5
Pastor shelf $5
Container full of body rubbers
Container full of shock and suspension rubbers $5
1L airbox top lid $5
3x hard top roof handle bar $2 for all
Suzuki bonnet badge $5
5 speed badge $10
2x sierra 1.3 badge $10
2x small Suzuki badge $3each
front brake lines $5
2x clutch cable $10
steering dampers standard $5
The bonnet stick that holds up the bonnet $5
Maybe 20 times original plastic clips that hold the door cards on $3
1L heater box fire wall rubber $2
A container full of body bungs
A container full of body bungs with holes for wires to run through them
I will swap for a good air compresor,air compresor hose.
Everything I am negotiable on. Need money for my jimny
brisbane north side Strathpine
Last edited by dougies_tx5turbo on Tue Nov 25, 2014 12:52 am, edited 58 times in total.
Vehicle: Sold zuk got a Bt50
Post Posted: Sat Dec 31, 2011 7:09 am
do you have a 3 into 2 brake block
Post Posted: Sat Dec 31, 2011 7:21 am
no it went with the chassis
Post Posted: Sat Dec 31, 2011 7:36 am
ok thanks
Post Posted: Sat Dec 31, 2011 8:49 am
im out on a limb i know but 1.3 starter motor?
Post Posted: Sat Dec 31, 2011 9:01 am
You have a pm
Post Posted: Sat Dec 31, 2011 9:38 am
no dont have one
Post Posted: Sat Dec 31, 2011 11:44 pm
Interested in your tyre bracket for the back door, will you post it up to Darwin for me..??
How is its condition..?
Post Posted: Sun Jan 01, 2012 3:45 am
yes i will post it. its in good condition i can get a picture up on tuesday night. i will find the weight out my post code is 4500.
Post Posted: Sun Jan 01, 2012 10:01 am
Okay thanks
Post Posted: Sat Jan 07, 2012 1:00 am
bump.
Last edited by dougies_tx5turbo on Mon Apr 02, 2012 5:55 pm, edited 1 time in total.
Post Posted: Thu Feb 02, 2012 4:33 pm
bump :D
Last edited by dougies_tx5turbo on Tue May 14, 2013 2:47 pm, edited 2 times in total.
Post Posted: Thu Feb 02, 2012 5:53 pm
the body rubbers which bit are they if they if they ones that are about 20mm thick and go under the car ill take them
rust is lighter then carbon fiber
Post Posted: Thu Feb 02, 2012 5:59 pm
will check but I am sure i have some, pm when you what to get them
Post Posted: Thu Feb 02, 2012 8:34 pm
Hey mate im chasing wt standard body blocks and bolts do u have any of this? removing body lift and dont have standard stuff
Post Posted: Thu Feb 02, 2012 8:51 pm
the bolts should be still on your body there is alot of square body rubbers I will check
Vehicle: Daisy
Post Posted: Thu Feb 02, 2012 9:07 pm
Hey mate, what condition is the drivers seat rail in? as well as the side indicator lens?
If they are good condition and will suit a WT, I'd like them both, I'm only on the gold coast but I'll pm you tomorrow to get details if they are in good condition.
Post Posted: Thu Feb 02, 2012 9:21 pm
drivers seat rails are in good condition, the lever side had a crack but has now been welded up and does not affect it. indicator lens is not cracked just needs a good scrub.
Vehicle: Daisy
Post Posted: Fri Feb 03, 2012 5:45 am
Ah well that's the same condition as mine, so don't worry about the rail, I wouldn't mind the indicator lens, any chance of post to gold coast? We are talking about the one that goes above the wheel arch right?
Post Posted: Fri Feb 03, 2012 1:36 pm
mate put pic up of the lense and there is a bit of a scrape off the top as you can see in the photo, should be able to put in an envelope and post.pm me if your keen.
Post Posted: Fri Feb 03, 2012 10:53 pm
hi mate how much tread is left on the tyres thanks
Post Posted: Sun Feb 05, 2012 11:45 am
thanks bud for buying the tyre's made my day :D :D
Vehicle: '84 LWB 1LTR
Post Posted: Tue Feb 07, 2012 1:54 pm
Hi mate I can be over thursday night to grab the stuff below if you still have it.
Cheers Nick
1L starter motor unknown condition $5
1L alternator unknown condition $5
1L 4 speed knob $5
1L tail lights $free
Brake booster $free
1L engine mount and bracket $10
2x door straps $5
1L acceleration pedal $3
Acceleration cable, good for a spare $5
6x 1L rubbers that go behind the 1L head light covers $2
2x 1L heater box fire wall rubber $2
1L steering columns $15
'86 SWB SIERRA 1.6EFI, '84 LWB SIERRA 1.0LTR
Post Posted: Tue Feb 07, 2012 9:26 pm
pm sent
Vehicle: sierra
Post Posted: Wed Feb 08, 2012 1:12 pm
hi, im interested in the rear diff housing, do you still have it? would i be able to come and have a look
Post Posted: Mon Feb 13, 2012 5:14 pm
bummp
Post Posted: Mon Feb 13, 2012 7:34 pm
Interested in a set of door hinges. Can you get a
Price for postage to 4812?
Post Posted: Mon Mar 19, 2012 1:38 pm
bumpp
Vehicle: 1991 SJ70
Post Posted: Wed Mar 21, 2012 8:39 pm
G'day Mate,
Whats left ?
Post Posted: Wed Mar 21, 2012 8:58 pm
everything that is listed and some other little random bits. i take them off the list when something is sold, so people know whats left.
Users browsing this forum: No registered users and 108 guests
