Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
Posted: Fri Feb 10, 2012 12:06 pm
Selling my ECU for an M18A with VVT Suzuki Liana Immobiliser, Key and ECU (all matched).
The Key casing is damaged, but it doesn't matter because you'll need to transfer the Chip and radio transponder into your own key anyway so no worries there.
I can provide Wiring manuals to go with it too, so if you need it for a Jimny Engine conversion you will have the elctrical manual to assist you, and I can supply the Jimny manuals too to compare. Also comes with the plugs from the ECU wiring loom with a few cm's of wiring still attached for you to splice into your own loom.
I was going to use in my own conversion to get the best out of my M18, but in the end I didn't have the confidence to replace it. I've had my vehicle engineered now, so i'm not going to change anything anymore. (I paid $400 for it,) but will take $200 inclusive of postage within australia.
Vehicle: m18 swapped in swift
Posted: Sun Mar 11, 2012 1:19 am
Hello
i have swapped m18 engine in swift 2010 successfully but running it on m13a non vvt ecu ..... i need this ecu with all can you contact me on email id : rafy_4u@hotmail.com so that we can discuss things in details thanks !!
Users browsing this forum: No registered users and 78 guests
