| (Vic) LWB Vitara stuff *Free* http://auszookers.com/forum/viewtopic.php?f=7&t=31256 |
| Author: | Gwagensteve [ Sun Mar 18, 2012 7:01 pm ] |
| Post subject: | (Vic) LWB Vitara stuff *Free* |
With the completion of the G16 conversion, the shell of the vitara donor has to go. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ALL PARTS ARE FREE The following parts are not available Rear axle housing, third member Front third member Split-Fold rear seat The car has no wiring loom, front brakes, steering box, fuel tank, engine or gearbox. Available: All panels (rear tailgate is junk, rear glass is smashed Shell - there is rust in the inner guard under the battery, and the floor has been cut in the rear for access to the spring buckets. Chassis has had the rear coil buckets removed and the steering box mount. Transfer case Radiator AC evaporator HVAC Front struts Alloy front axlehousing CV's Dash Front seats Rear axles A Arms etc. Driveshafts All parts are pickup only. I'm not freighting. I'm not driving stuff all over Melbourne. Car is located in Kinglake. Come and help yourself I also have another set of front guards/bonnet, SWB doors, various vitara hubs etc. In a couple of weeks the whole lot will go to the tip regardless of what's taken or not. I have too much stuff as it is. PM me if you are interested in anything. Steve. |
| Author: | Gwagensteve [ Sun Mar 18, 2012 7:03 pm ] |
| Post subject: | Re: (Vic) LWB Vitara stuff *Free* |
Oh, as you can see in the photos, the LHS panels are rough - I think the car has run along a fence. The paint is obviously rough - the clear coat has lifted all over the place. Steve. |
| Author: | brando93 [ Sun Mar 18, 2012 8:26 pm ] |
I'l take switch combo unit and steering wheel if its there?? Cant tell from pics |
| Author: | Gwagensteve [ Sun Mar 18, 2012 8:39 pm ] |
Column is gone. Wheel is there. Steve |
| Author: | FullyZooked [ Sun Mar 18, 2012 8:41 pm ] |
Hey Steve I'll grab the cvs if they are ok. Do you know if there flogged out? |
| Author: | Daves4wd [ Sun Mar 18, 2012 8:42 pm ] |
Have you got the hubs?? I'll grab them if there in working order and part time to please |
| Author: | Gwagensteve [ Sun Mar 18, 2012 8:46 pm ] |
Hubs and cv's are available. I have no idea of the condition, but the car seems to have done very little off road work and is clean. Steve |
| Author: | Built4thrashing [ Mon Mar 19, 2012 4:07 pm ] |
If i can organise myself ill come grab the lower front control arms. How long till it goes to the scrap man? |
| Author: | Daves4wd [ Mon Mar 19, 2012 4:52 pm ] |
Yet I'll take the hubs can I pick them up one night this week and the front calipers can you use ten for the Seirra upgrade??? |
| Author: | Gwagensteve [ Mon Mar 19, 2012 4:59 pm ] |
B4T: A couple of weeks. I'll probably bin it during easter. So far Fullyzooked has spoken for the cvs and also the drag link, idler arm and tie rods. B4T: Front arms Daves4WD - Hubs - yes they are part time. I have no idea if they work or not, but have no evidence that they don't. Quote: The car has no wiring loom, front brakes, steering box, fuel tank, engine or gearbox. My word the front brakes are an upgrade for a Sierra - that's why they are in mine. PM me to arrange a time to come and pickup. |
| Author: | Daves4wd [ Mon Mar 19, 2012 6:31 pm ] |
Ahhh I missed that on that on bugger hahah |
| Author: | Plum [ Mon Mar 19, 2012 9:31 pm ] |
PM'd for rear axles. |
| Author: | mika [ Tue Mar 20, 2012 5:06 pm ] |
I'm guessing you used it when you did your power steer but incase you didn't i'm after a vitara steer column (box to firewall) |
| Author: | Gwagensteve [ Tue Mar 20, 2012 5:33 pm ] |
I think there is might be couple on the shed. There's a couple of different styles - Give me a call so I can work out what you need. Steve. |
| Author: | orangeshannon [ Wed Mar 21, 2012 5:39 am ] |
hey mate im after that little plastic bar that runs across the fron of the car between the front bumper and just underneath the front head lights and possiably other bits but will have a look when i get home to see what i need |
| Author: | Gwagensteve [ Wed Mar 21, 2012 7:24 am ] |
It's broken on the car I have- it's had a small hit. Steve |
| Author: | GOMEZ [ Wed Mar 21, 2012 9:46 am ] |
Hi Steve If it's not gone, I will take the complete rear bar with lights. Also the right front guard if that's ok. Also the power window door lock switch on inner drivers door arm rest. Thats it. Thanks. Could you please txt me your details & what day suits you for pickup. 0402460578. Also the centre rear part of console hand brake surround. Thanks Steve. |
| Author: | orangeshannon [ Wed Mar 21, 2012 10:50 am ] |
i would also be interested in all inner door pannels my front ones are not to good power windows surrounding is stuffed and possiably the power window switches aswell if GOMEZ don't take them all haha |
| Author: | Gwagensteve [ Thu Mar 22, 2012 5:12 pm ] |
So far Fullyzooked has spoken for the cvs and also the drag link, idler arm and tie rods. B4T: Front arms Daves4WD - Hubs - yes they are part time. I have no idea if they work or not, but have no evidence that they don't. Gomez: Rear Bar, front right hand guard, driver's door lock/window switch panel. The console is OK but the little door on the rear section is broken/missing like they all are. Orangeshannon - door trims (they aren't perfect though) and all remaining switches. You're welcome to the grille/trim panel as is if you are interested. I think I have another one behind the shed too. PM me to arrange a time to come and pickup. I'm not chasing people with texts. I will PM people with my address and when it's convenient to come and grab stuff. Steve. |
| Author: | Gwagensteve [ Sun Apr 01, 2012 4:22 pm ] |
Gomez has grabbed the rear bar, centre console, driver's door switches and RHF guard. Orangeshannon has grabbed all the doors. Fullyzooked has yet to contact me for a time to pick up the CV's, drag link, idler arm and tie rods. Plum has contacted me regarding axles At this stage, it's going down the tip the week after easter. Steve. |
| Author: | bumpyzook [ Mon Jul 15, 2013 3:24 pm ] |
| Post subject: | |
just wondering if i could grab the bonnet front drivers light front drivers panel front cross bar passenger side front panel front grill dont care if it has a small crack and also the passenger side light |
| Author: | DarkHorse [ Wed Jul 17, 2013 12:09 am ] |
Given that the last thing he wrote was that it was going to the tip the week after Easter LAST YEAR I don't like your chances... |
| Author: | atari4x4 [ Wed Jul 17, 2013 12:12 am ] |
golden grave dig |
