| Bullbar for Sierra Melbourne http://auszookers.com/forum/viewtopic.php?f=7&t=31370 |
| Author: | jonfromhamilton [ Thu Mar 22, 2012 8:18 pm ] |
| Post subject: | Bullbar for Sierra Melbourne |
$100, pick up only from Melbourne S.E Suburbs this Bullbar comes apart into 7 differnet parts and bolts together. Pipes dont run continuous through vertical supports, they are bolted together, by about half inch diameter bolts. Probably not the the strongest bar but would still cave a dwarfs head in if you hit them at speed. ![]() ![]()
| Author: | jdk81 [ Thu Mar 22, 2012 8:41 pm ] |
| Post subject: | Re: Bullbar for Sierra Melbourne |
jonfromhamilton wrote: Probably not the the strongest bar but would still cave a dwarfs head in if you hit them at speed. Is that the new ADR requirement that they were talking about in the news paper the other day? Good luck with the sale! Now, if only they can make a car attachment to specifically target gingers. |
| Author: | jonfromhamilton [ Sat Mar 24, 2012 8:15 pm ] |
Bump offers ? |
| Author: | jonfromhamilton [ Sun Mar 25, 2012 7:47 pm ] |
50 bucks ? I don't want it. |
| Author: | stockman [ Sun Mar 25, 2012 7:55 pm ] |
Is it plastic? |
| Author: | Gwagensteve [ Sun Mar 25, 2012 8:14 pm ] |
stockman wrote: Is it plastic? Ouch! |
| Author: | SUPAZOOK [ Sun Mar 25, 2012 8:37 pm ] |
This wouldn't fit a Coily would it? |
| Author: | stockman [ Sun Mar 25, 2012 8:47 pm ] |
Gwagensteve wrote: stockman wrote: Is it plastic? Ouch! The uprights look plastic |
| Author: | jonfromhamilton [ Mon Mar 26, 2012 6:24 pm ] |
the uprights are steel coated in rubber. they bolt on pretty simply to my WT chassis, you may be able to modify them for a coily or they may just bolt straight on, I have no idea really. I'm sure you could rig something up. buuuuuuuuuddy (like pauly shore) |
| Author: | PJ.zook [ Mon Mar 26, 2012 6:48 pm ] |
Shove it out the back of the shed incase you need to cut it up later and use the bends. |
