It is currently Tue Oct 27, 2026 1:49 pm
Post Posted: Sat Mar 24, 2012 12:43 pm
For those that haven't read the tech section for a while ive designed and made a bolt on skid plate for the gearbox crossmember on the 99-05 GV.
so rather just make one for myself iv'e made a few with the plan to sell them.
Vit ones also available.
To fit you need to drill a M10 hole in the top skin of the crossmember. Then its all just bolt on. Takes about 5 minutes to fit.
Comes with all bolts needed to install.
Let me know via PM if you want one.
Last edited by Built4thrashing on Thu Apr 26, 2018 7:14 pm, edited 5 times in total.
Post Posted: Sat Mar 24, 2012 3:05 pm
Got a photo of one installed mate?
Moses' SQ625 GV Pig
Post Posted: Sat Mar 24, 2012 8:20 pm
Not yet but can get for you.
Post Posted: Sun Mar 25, 2012 1:21 pm
Installed pics as promised.
skid plate, accessories and tools needed for install
Drill hole in top of crossmember. There is already a hole in the botom skin. You just need to drill up through there. May need to oval top hole slightly for bolt to go through... some bolts may not be welded on perfectly square.
Use sandwich plate and screw on nylock. Only do it up finger tight untill rear clamps are in place.
Yes it looks very close but its just the camera angle. There is 20mm clearance between bolt head and tailshaft.
once in place tighten everything up and you finished.
Last edited by Built4thrashing on Mon Mar 26, 2012 11:05 am, edited 1 time in total.
Post Posted: Mon Mar 26, 2012 11:00 am
Only one left from the original batch. Once its sold ill make another 5.
Payment by EFT or cash on pickup.
Post Posted: Mon Mar 26, 2012 12:06 pm
OK last just sold.
well not compltely true. one will be selling on ebay starting tonight.
Ill have some more ready next week.
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Mon Mar 26, 2012 12:44 pm
how much difference are they to a swb vit?
Post Posted: Mon Mar 26, 2012 2:22 pm
I have no idea. Im going to look at a LWB vit tomorrow after work to see what needs to be for it to fit them. then ill look at a SWB GV's and SWB Vits.
Vehicle: Suzuki 2003 GV and Sierra 1988
Post Posted: Mon Mar 26, 2012 2:56 pm
Do you reckon you could make one that goes the full width of the cross member or perhaps I just get 2...
The leading edge of my cross member is all bent backwards and out of shape so I want to stop that from
happening again before I bash it back to straight or fit a new one.
Brad Jones - Geek - www.gravit.com.au - 0407961903
Post Posted: Mon Mar 26, 2012 3:06 pm
to do that would add alot of extra weight and postage would be very expensive.
If you have to remove it to straighten it then get a bit of sheet metal welded to it. Most the hits i got on my crossmember were inthe middle. this skid plate sits slightly lower than the cross member and will be the first thing to get hit. I can get them made wider if required but it wont be much benifit. Will just add extra weight and be more difficult to attatch to the cross member.
Pm me and i can talk to you more about what you want.
Post Posted: Mon Mar 26, 2012 4:43 pm
ok first batch is all sold.......even the ebay one is sold. Next batch will be ready hopefully by end of the week.
Vehicle: 1999 Jimny
Post Posted: Mon Mar 26, 2012 7:02 pm
Sounds good, will be on my to buy list when I get mine home... :D
Post Posted: Mon Mar 26, 2012 8:20 pm
Ill let ya know when the next lot are ready.
Post Posted: Wed Mar 28, 2012 3:31 pm
Just a quick edit for these. Postage has gone up. I need to allow $35 for postage and handeling. Aparently Aus post measuer things differently......Plus it needs to be wrapped up more......
Next lot will be ready soon.
Users browsing this forum: No registered users and 73 guests
