It is currently Tue Oct 27, 2026 1:22 am
Vehicle: yellow 83 sierra
Post Posted: Sun Sep 18, 2011 7:11 am
hi i have a 92 G16B block up for sale the head was removed only to be put on another engine but ran fine no problems $300
also
G16B head need rebuild in bits and peices at the moment $100
a auto out of a 92 LWB vitara estate $300
G16B EFI inlet manifold with some wiring $100
92 ECU (auto) $100
pm me for better prices
Melbounre pick up or could drop off anywhere around melbourne for an extra cost
Vehicle: vitara
Post Posted: Thu Apr 19, 2012 4:20 pm
G'day my names Tyler, I was wondering if you still had the block for sale?? PLEASE EMAIL ME ASAP! at tyler.cuttle@gmail.com
Post Posted: Fri Apr 20, 2012 12:05 pm
the parts i have left over is the
head with all the bits in a box $50
transfer case in very good condition (the oil was bright red like it just had been serviced but it wasnt) $200
front and rear driveshafts $60 for both or $30 each
complete exhaust minus the manifold (in good condition) $50
efi dizzy complete with the 90 degree mount that bolts to back of head with leads $50
aircon pump $100
efi airflow sensor $150
ignition coil (works great) $50
painted metalic red rocker cover been fully sand blasted $20
i would like them gone just taking up room i don't have.
pick up from burwood
i might also have a few other little bit and peices
Post Posted: Fri Apr 20, 2012 9:26 pm
Did you have full efi wiring harness??
Vehicle: 4wd
Post Posted: Fri Apr 20, 2012 10:22 pm
G'day Tyler.
Watch out or you'll get sued.
Post Posted: Tue Apr 24, 2012 9:11 am
I also have a 16valve camshaft with came gear on it swell $100
Make me an offer on any of my parts I would like them gone as I have no need for them
Post Posted: Wed Apr 25, 2012 8:45 am
Hi, I will take the head if you will post to NSW for me?
Tony
Post Posted: Wed Apr 25, 2012 9:49 am
NOTE THE 16V HEAD WAS CRACKED AWHILE BACK N WELDED UP AND WHEN I TOOK IT TO THE MACHINE SHOP THEY SAID THAT IT CRACKED AGAIN AND HAD GONE SOFT. ALSO F u want the head its just the head including came gear but no cam
Post Posted: Wed Apr 25, 2012 12:18 pm
OK - PM'd
Post Posted: Thu Apr 26, 2012 6:23 am
getting rid of the head without anything on or in it take it you want to need it gone
$50 for all the head parts minus cam shaft
Post Posted: Fri Apr 27, 2012 12:03 pm
air flow meter 5 pin
Post Posted: Fri Apr 27, 2012 12:13 pm
few more parts of pics
exhaust in car pic but is not in car anymore
red rocker cover
camshaft
AFM
Users browsing this forum: No registered users and 67 guests
