Vehicle: Zook
Posted: Tue Jun 05, 2012 11:29 am
For sale are x2 (1x drivers and 1x passengers) Calmini HD rear axles. These are brand new. To suit a WT. I was going to fit them, however due to unforeseen circumstances it's not going to happen.
Details..
Brand new replacement Calmini Heavy Duty forged rear axle shafts for the Suzuki Samurai. Finally an easy solution to running larger off-road tires and beefing up the stock axle setup. Axles are 30% stronger than factory and made from 4140 alloy steel. These heavy duty axles match the factory 26 spline setup and swap in easily. These axles greatly reduce the chance or breaking or shearing in off road situations. Also recommend if you are running a locker with large tires.
$400 shipped to your door. These will be packaged in a box. I will take care of the freight.
These are located in Geelong so pickup is also an option.
Cheers, Paul
Users browsing this forum: Google [Bot] and 50 guests
