It is currently Fri Oct 02, 2026 7:15 pm
Post Posted: Wed Jun 13, 2012 12:56 pm
1.6 swift engine , comes with h4 ecu and loom , also will throw in a h5 ecu and loom. $350
1.6 single point injection setup to suit g13 or g16 8 valve . $150
1.3 alternator , almost new done less than 50km's !!! . $100
1.3 starter motor , perfect working order. $40
1.3 electronic distributor . perfect working order. $40
1.3 coil , perfect working order. $10
bolt on bullbar/ bar top . bolts on top of factory bar. free damaged front bar with bar top . $50
custom f series crank pulley . supercharge your f series engine or run another accessory!!! I made this out of 2011 grade aluminium , the aluminium cost me $80 alone and then machine work , it does require a keyway to be broached though , which any engineering shop can do for a small price. $50
also i have a 1.6 bare block bored honed and decked with new 8 valve pistons , rings and gudgeon pins , however the block has a very small crack in the water jacket only at the front left hand side of the block . the crack was only discovered after a thorough cleaning of the block. looking for $250 which is less than the price of the piston set. pictures can be taken for interested buyer.
everything located southside brisbane smaller items can be posted at buyers expense .
Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic.
Please like and share my facebook page - www.facebook.com/suzukimechanic
Post Posted: Wed Jun 13, 2012 4:29 pm
Pm sent for injection
Post Posted: Wed Jun 13, 2012 7:30 pm
whats the difference between the h4 and h5 ecu?
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Sun Jun 17, 2012 4:55 pm
Id have to consult my partfinder which i dont have access to atm. But both ecus and looms.will run this engine....
Post Posted: Fri Jun 29, 2012 7:41 pm
Starter and injection kit sold . Open to offers on other stuff.
Users browsing this forum: No registered users and 20 guests
