It is currently Wed Oct 07, 2026 7:47 am
Vehicle: A shed full of pieces so far
Post Posted: Thu Jun 28, 2012 9:34 pm
Time to clear some shed space.
I have
Ben T g16 engine mount adapter(only the drivers side mount and the spacers for the passengers side) $50
Trail tough crank pulley V belt inner multi rib outer. Suit power steering. $50
Both brand new never used
Like new 1L brake master cylinder $30
Above can be posted and are ready to go
The following will be ready 11/7/12
F10a and 4 speed complete from radiator to jackshaft. Starter alternator etc.
Has brand new HD clutch only travelled about 30km. Felt good not heavy or anything.
Engine runs quite smooth but is smokey.
Reverse gears are rooted. Rest of gearbox looked reasonable for parts. No chipped gears other than reverse.
$250 for the clutch n you can have the rest if you want.
Will part out if your only after bits.
Front and rear 1L diffs drum to drum $75 each
PM for more info
Mitch
Post Posted: Thu Jun 28, 2012 10:07 pm
I am located in toowoomba QLD
Users browsing this forum: No registered users and 10 guests
