Only fault that I am aware of mechanically is an oil leak which I think is coming from the distributor shaft, so should just require a new seal.
The body is in good condition except for the rear door and bumper which has been damaged in an accident. Door still opens and closes and I don't think it would need to be repaired for a Blue slip.
The two rear doors also have a little rust near the rubbers on the window seals in one spot on each side.
I have recently replaced the water pump. The tyres are in good condition.
I really dont think that it would require too much to register this car, It has been very reliable while we have had it.
Selling unregistered - had QLD rego that has run out.
Users browsing this forum: Google Adsense [Bot] and 49 guests
