It is currently Wed Oct 28, 2026 5:58 pm
Post Posted: Tue Jul 31, 2012 8:15 pm
Hi guys. I'm cleaning out all my projects lying around so I can start fresh. Got a bunch of Sierra and vitara parts that I want to move.
Front wt hubs need a clean. $10
Lwb vitara calipers. $50
Sold
Sold
Bag of sting perches, u bolts, timing sprockets, double v belt pulley and gearbox inspection plate. $10
Set of 4 Suzuki mudflats, one bent, two have split bolt holes. $10
Steel airbox. Circular inlet + outlet. From 90's lancer. $20
Sierra tail lens. Dirty but no cracks. $10
Vitara 1.6 mpfi head. Good for parts, missing a few inlet rockers, cam suit regrind. $50
Vitara 1.6 mpfi block. Suit parts or rebuild. No 4 piston suspected big end bearing. Bores look okay. $50
Vitara rear axle bearings new in box. $25
Sierra rear axle bearings new in box. $25
Sierra hub kit, felt, rubber, king pins and axle seals. $25
Wt front housing with jig to make it nt spacing. With bag of laser cut perches. $50
5.12 center in vitara alloy housing. Cracked outer section. $50
Sold
Sierra calipers. $10
Wt steering box and links. $75
Item are located in smiths gully. I am happy to post, or can organise a pallet to drop off at a courier (campbellfield or laverton) or can meet on the ring road after work.
Any questions just shoot me a pm.
Cheers Vince.
Post Posted: Tue Jul 31, 2012 8:18 pm
also forgot, photo's.
http://s225.photobucket.com/albums/dd21 ... 002/parts/
Vehicle: Sold the Project :-(
Post Posted: Tue Jul 31, 2012 11:12 pm
Sierra snorkel stainless steel with silicon bends. $50
5.12 diff in sierra housing welded locker. $50
Wt rear diff. 5.12 ratio with auto locker. $350
New lwb vitara vented rotors. $50
Cheers Vince.
G'day Vince
Mate I'm keen on all that is Red above. Can we work out a price on all that Bud? consider it sold.
Cheers Darren
Just bought a NT LWB Sierra! Let the Mods begin!
Post Posted: Wed Aug 01, 2012 7:07 am
I will take the 5.12 center in alloy housing mate. Will pm you now.
Dave
Vehicle: 2000 suzuki jimny
Post Posted: Wed Aug 01, 2012 8:11 am
Will the hubs fit a jimny if so pm me
Post Posted: Wed Aug 01, 2012 10:29 am
You got a pm.... But chuck the Vitara callepers on me tab!!!! Hahaha
back in a built sierra!
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Wed Aug 01, 2012 10:33 am
How. Much for wt diff centre with locker posted?
if u don't get stuck u ain't trying hard enough
Post Posted: Wed Aug 01, 2012 10:24 pm
ok guys ill start replying over the next couple of days
Users browsing this forum: No registered users and 71 guests
