It is currently Mon Nov 02, 2026 3:52 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
Vehicle: Sierra
Post Posted: Mon Dec 17, 2012 9:31 pm
Top
1991 widetrack hardtop Suzuki Sierra in white $4,000 ONO
229,000kms
VIC REGO till May 2013
Fully reconditioned engine 10,000km ago at suziworld
Extractors
Dual battery system with upgraded batteries
Upgraded radiator with thermo fan and on/off switch wired to ignition
Brand new clutch and transmission rebuilt recently
New front and rear wheel bearings
31" muddies on sunraysias
2" body lift
2" suspension lift
UHF with sprung aerial. UHF mounted on roof map tray
Autotecnica racing seats
Sports steering wheel
Bullbar
Snorkel
Led spotlights wired to the high beam with additional on/off switch
IPF upgraded lights with higher output globes (The globes are legal, same wattage with higher lumens output)
LED indicators
Sony head unit with tweeters on the dash, 6 inch in the foot well and 6x9 in the rear. 3.5mm audio input
Inbuilt 300w inverter behind side wall in the rear, provided with 240v plug and on/off switch with indicator light
2 x Cigarette lighters in the rear setup for a fridge
Stereo, cigarette lights, inverter, spotlights and UHF all run off the second battery
Has the rear seats and belts currently installed
Rear tie down points for gear and fridge
Custom built roof racks
Custom made storage compartment in the back
The car is wonderfully finished with marine carpet which is easily removable for cleaning
Internal LED map light with switch
I have extended break lines ready to go in and central locking kit 90% installed to go with it.
The car has had regular servicing and maintenance with no oil leaks
Selling due to needing a larger 4x4. This 4x4 has been great fun and proved to be very capable offroad. Will be sad to see it go after many years of enjoyment.
The car is located in Eynesbury 3338 40min west of Melbourne and 10min south of Melton, Victoria.
Please call if you have any questions. 0422 638 892
Thanks
Dale
Vehicle: Sierra
Post Posted: Mon Dec 17, 2012 9:34 pm
Top
More pictures
Vehicle: 96 vit hardtop
Post Posted: Tue Dec 18, 2012 1:23 pm
Top
What is that thing you've taken so many pics of with the carpet section removed?
Trying to work it out.
Vehicle: Yellow Ute
Post Posted: Tue Dec 18, 2012 2:44 pm
Top
Drug compartment.
Vehicle: Sierra
Post Posted: Fri Dec 21, 2012 6:25 am
Top
Sold :)
Users browsing this forum: No registered users and 21 guests
