It is currently Sat Oct 10, 2026 2:09 am
Vehicle: 2018 DMAX
Post Posted: Wed Jan 23, 2013 8:22 am
Will be more bits to add as I find them. Pick up only, if you want freight you organize it( 4114 ). Nothing will be put on hold.
1. 4x BFG KM2 31/10.5/15 Did two trips on them, 2 look new, two have been scrubbed up by the locker. No rims. $800 SOLD
2. 5x Dunlop Grandtrek 205/70/15 Approx. 6mm of tread. Fitted to stock sierra rims, need painting. Good for RWC. $150
3. G16B. Early model denso Vitara. Unknown KM/history. I have been running it for the last 12 months without problems. IF it sat it blew smoke on start with standard oil, seems fine with something thicker. Motor will have ancillaries fitted, comes with AFM, coil, leads, airbox. No loom, I can provide ECU but it will need replacing. It is currently fitted and can be seen running (for now at least). /forgot to add, timing belt and water pump replaced 6mths ago. $500
4. Stock NT 1.3 transfer. Is currently fitted to my daily drive and seems to work fine. $250
5. Extractors suit G16b, have been bashed to fit into a sierra. No flange. $80.
6. 2008 XR250L 11,000km, Motor was sleeved and ringed by my dealer at 9500km, had new clutch and all gaskets replaced. Recently had new chain/sprockets so these should be good for awhile. Base gasket has a weap. Battery is dead. Requires new clutch lever, it will be replaced before sold. Plated as single seat. Rego till the 22/2/13, can be test ridden untill then. Sold with out rego, is as is condition. $3900
7. New Abney level in leather case with lanyard. Stolen from wikipedia "used to measure degrees, percent of grade, topographic elevation, and chainage correction. By using trigonometry the user of a Topographic Abney Level can determine height, volume, and grade" $75
8. Masterlock pad lock. $5
9. Blow off valve, $10
10. Malpassi rising rate fuel reg. $50
11.Autometer elec oil pressure gauge, carbon fiber. need to check size. Has no sender. $90
12. Fuel tank with ODA bash guard. Sierra. $75
13. 3.9 third, nasty bearings. R&P should be good.22 spline $30
14. center, 22 spline 4 pin. $25
Plus other bits, check the photos.
Assorted interior bits, I have seat belts, buckles, door handles, winders, dash bits - Tell me what you need and I will see what I have.
Post Posted: Wed Jan 23, 2013 10:58 am
very keen on the KM2's, but i will need to organise freight to SA.
can you chuck one on the scales so i can get some quotes, i'm guessing 20kgs each?
pics would be sweet when you get the chance.
Post Posted: Wed Jan 23, 2013 12:39 pm
according to bfgoodrichs site. they are 21.2 kg
Post Posted: Wed Jan 23, 2013 1:39 pm
cheers tanshi, should have thought of that :oops:
sussing out quotes now boostedbrick to see if it's a viable option.
Vehicle: 2018 DMAX
Post Posted: Wed Jan 23, 2013 7:44 pm
Post Posted: Wed Jan 23, 2013 7:50 pm
I'll take them Armsup
PM replied
Vehicle: Sold zuk got a Bt50
Post Posted: Wed Jan 23, 2013 9:07 pm
Dam you ^^
Post Posted: Wed Jan 23, 2013 9:39 pm
don't really need tyres yet but my MT/R's have 80,000kms + on them so they're starting to get low, i'll swap them onto the trailer & run the BFG's.
KM2's have been on my short list for replacement tyres, looks like I had the decision made for me when these popped up.
Post Posted: Thu Jan 24, 2013 8:11 am
I lust after these tyres too, but not yet
Vehicle: 1985 Sj40 Suzuki sierra
Post Posted: Tue Jan 29, 2013 4:08 pm
Hey just wondering if those grand trek dunlops are h/w tread or A/T?
Vehicle: 2018 DMAX
Post Posted: Mon Feb 04, 2013 8:00 am
They are AT/s .
Vehicle: 2018 DMAX
Post Posted: Sun Feb 10, 2013 3:54 pm
More stuff added
Post Posted: Sun Feb 10, 2013 4:21 pm
Is it a Vit or Sierra fuel tank?
Vehicle: 2018 DMAX
Post Posted: Sun Feb 10, 2013 5:06 pm
Sierra.
Post Posted: Sun Feb 10, 2013 8:10 pm
Whats the dimensions on that blow off valve? Wonder if its small enough for my bike project :D
Got a EFI vit one here if that what you were chasing?
Vehicle: Sierra SJ50
Post Posted: Sun Feb 10, 2013 9:34 pm
Still got that engine?
Vehicle: 2018 DMAX
Post Posted: Mon Feb 11, 2013 7:54 am
Yes
Users browsing this forum: No registered users and 58 guests
