Page 1 of 1
[ 10 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
podger
Vehicle: 1990 swb vitara 1.6 5speed
 Posted: Tue Feb 26, 2013 8:36 pm |
FOR SALE 89 swb vitara white manual 302 588 km's
things that i have done over the 4000km, repaired, new or have replaced and modified
2 inch lift out of LWB, about 2.5 inches on the swb new BFG KM2 MT 235/75/r15 on aftermarket rims new firestone 205/75/r15 on factory rims high flow cat and muffler back exhaust rebuilt cv's new front wheel bearing kits new front pads new rear drums, shoes and wheel cylinders new rhf window new power widow reg's roof racks, not fitted new front control arm bushes new front shockies new front shockies drop sleves new rear commodore shockies new A arm drop bracket extended diff, tranfer and gear box breathers to engine bay new master window switch complete a/c set up, not fitted bash plate for engine and gear box, not fitted all oil replaced service items, spark plugs, lead, cap, rotor, air filter, oil filter, timing belt, cam seal, crank seal, oil pump gasket, reseal sump, carby vacuum lines, wiper blades, cam cover gasket coolant change, all hoses replaced, radiator, cap, water pump rear diff lock right auto locker with all seals and bearings replaced new snorkel new front diff drop brakets ARB bull bar tow bar spot lights, not wired up A arm drop bracket aftermarket cd player and speakers temp and voltage gauges camber bolts avg hub lock's wheel bearing adjuster tool
lots of extra's
things that need to be done fix steering wheel so that the indicator cancel alt noisy
mate and i have cut, repaired, treated, prime and painted any rust that we found
no rwc rego run out in 5 month 2013 can drop any where in south east qld for a fee
body ok interior ok
price $3250 neg alot neg
location rosewood qld 20 mins out of ipswich
contact pm john message me on 0410418081
Arinvar
Joined: Mon Aug 06, 2012 9:49 pm Posts: 85 Location: Ipswich
Vehicle: Sierra SJ50
 Posted: Tue Feb 26, 2013 8:47 pm |
podger
 Posted: Tue Feb 26, 2013 8:55 pm |
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Tue Feb 26, 2013 9:01 pm |
That's a tidy car for $3500
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
podger
 Posted: Fri Mar 01, 2013 7:16 pm |
podger
 Posted: Wed Mar 06, 2013 7:53 pm |
podger
 Posted: Sun Mar 10, 2013 8:37 am |
ozhummer
Joined: Fri Feb 12, 2010 10:30 pm Posts: 284 Location: Brisbane
 Posted: Sun Mar 10, 2013 2:05 pm |
Im interested in the ac if you want to sell it on its own?
podger
 Posted: Mon Mar 11, 2013 6:29 pm |
ozhummer wrote: Im interested in the ac if you want to sell it on its own? pm
podger
 Posted: Fri Mar 15, 2013 6:50 pm |
Page 1 of 1
[ 10 posts ] |
Users browsing this forum: No registered users and 13 guests
