Joined: Sun Apr 17, 2011 7:27 am Posts: 210 Location: Keilor
Vehicle: 92 tintop sierra
Posted: Sun Mar 03, 2013 8:32 pm
Well im not sure weather this is a grand idea, or ill just get laughed at.....But here we go
93 tintop sierra, Just payed the rego acouple days ago. Wont come with a roady as it'll need to be of the special variety.
g16b vitara engine swap, removed from a wreck with 150,000 kms. Timing belt and water pump replaced recently Good quality thorley extractors with 2" exhaust External efi pump with low pressure lift pump TSOR tank guard BenT adaptor kit
New exedy clutch with engine swap acouple months ago Just had gearbox out to replace both input and output shaft seals and replace a noisey bearing Trail gear 6.5's with complete transfer overhaul supliment BenT transfer arms Rear mini spool New rear wheel bearings a fortnight ago Just replaced clutch cable and gearbox mount
New efs springs about a month ago Std 2wd hilux rear shocks, bluepack front shocks trail tough 1" extended shackles BenT power steer kit with vitara box
LWB vitara front rotors and calipers extended braided lines rear shoes and cylinders done recently
JML front winch bar warn 9000lb winch IPF extreme sports with HID TSOR body lift with new aftermarket body rubber mounts
Swift gti seats Big mofo rear draw
15x7 sunnies with 80% 31" buck shots, new spare on tailgate.
ANd other shit thats not yet fitted: UHF cromo axles and cvs lockrite for front KOYO front swivel rebuild kit Dyneema rope and fairlead (Just in process of upgrading winch solenoid and rope) New timing cover
Condition wise it is good, paint on roof and such has pealing clear coat. Afew dents but nothing major. Mechanically it is sound, Got a whine from i think the diff gears. Also has a broken body mounting stud under throttle pedal which i dodgied up.
Price 8,000
Located in melbourne.
Users browsing this forum: No registered users and 36 guests
