It is currently Mon Nov 02, 2026 8:12 am
Vehicle: 1990 Suzuki Vitara Swb 1.6Ltr
Post Posted: Mon Mar 04, 2013 4:10 pm
Hi there guys,
I have a set of Front and Rear Sierra Diff's for sale.
They are Spring Over Axle and Wide Tracked.
I have no idea what the ratio is because i was given them for the tires
that were on them.
The rear diff has been changed from a drum brake to a disk brake conversion.
I'm asking $350 but ill take $300
I also have 4 31-10 All Terrain Tire's.
70% tread on all 4.
SOLD
Pick up only .... Item's location is Maitland Area
Vehicle: 4wd
Post Posted: Mon Mar 04, 2013 4:34 pm
They look like OME springs. Worth a couple of hunge alone if they are.
Watch out or you'll get sued.
Vehicle: LJ50V, SJ70
Post Posted: Mon Mar 04, 2013 5:00 pm
And the diffs have been SPOA'd.
Post Posted: Tue Mar 05, 2013 8:39 am
So Spring over Axle is worth a bit more? Could someone message me and explain this to me?
Post Posted: Tue Mar 05, 2013 10:19 am
No probs not Bidz, If they were SPUA and NT width people would pay bucketloads for them, but because there SPOA and I assume WT, it's not worth that much more.
The springs might be worth something tho, I'll have a look this arvo for you ;)
Post Posted: Tue Mar 05, 2013 10:36 am
Spring over actually devalues the diffs, however you do have wide track diffs, which are what everyone wants. The purchs have been moved to narrow track spacing, not that means anything as they are on the wrong side of the tube. Dollars you're asking are about right given the condition. Disc rear is worth more but without more info and from the looks they'll need reconditioning so it's hard to tell.
Post Posted: Tue Mar 05, 2013 10:39 am
good price as far as i can see.
i would have grabbed them if they were in qld
Post Posted: Tue Mar 05, 2013 11:42 am
Guess i have a good set of diff's for sale then :)
Post Posted: Thu Mar 07, 2013 1:25 pm
Hey guys, the diffs have the good :D the rear one has a big machined alloy brake caliper holder and the rear brakes have a hand brake function with all the cables hooked up. They also appear to be NT SPOA... and the front diff has a giant tierod.
I'm not sure of the internals, but the outside looks pretty good :D
