It is currently Thu Nov 05, 2026 2:24 am
Post Posted: Tue Mar 05, 2013 10:47 am
I have a 2008 J20A long Bare motor in excellent condition from an auto SX4
Has injectors, rails, part of wiring and plastic inlet manifold flanges cut 3 inches
off the head was going to use rwd manifold or custom and headers.
no waterpump, alternator, starter totally unopened J20A Long Bare engine.
This engine can suit a vitara 2ltr using rear dizzie head or late ecu using cam sensor
Also J series of this model match the g16b gearbox then need ecu
or any auto vitara gearbox to suit G16b or J series.
Can also use RingR adaptor to suit toyota gearbox
Price:
$800 plus freight
$600 bottom end plus freight
$200 head plus freight
will also swap for good late model Jimny M series gearbox freighted to Melbourne.
Post Posted: Thu Mar 07, 2013 10:01 pm
Jimny gearbox needed for M18a
Post Posted: Fri Mar 08, 2013 1:38 pm
How it would look in a vit with gsxr itbs :beer:
First start of one in a vitara
http://www.youtube.com/watch?v=_4OGbDAE5No
also one with stock vitara manifold but megajolt & factory exhaust header
http://www.youtube.com/watch?v=9XqVHIce0_M
Post Posted: Sun Mar 10, 2013 9:15 pm
150hp
Post Posted: Tue Mar 19, 2013 7:04 pm
sold to Adam
Post Posted: Tue Mar 19, 2013 8:11 pm
Can I have some pics of the SX4 motor? I suspect that the sump arrangement is dramaticly different to vitara.
Post Posted: Wed Mar 20, 2013 11:58 am
This is a vitara sump from the net its not very different in fact the vitara sump is deeper from mid to rear
while the sx4 front hump is bulkier but not dramatically compared to vitara sump depth.
http://www.foo.is/albums/j20a/S2010209.jpg
http://www.foo.is/albums/j20a/S2010202.jpg
here is a manifold for sale on Gummy, a bit steep though
http://www.gumtree.com.au/s-ad/mansfiel ... 1014354449
here is the j20a in a heavy vitara
Post Posted: Wed Mar 20, 2013 1:25 pm
Thanks for the pics. But as I suspected, the sump and subsequent bottom block casting ( see the horizontal seam under the oil filter ) is reversed. It may be interchangable with the J20 vitara casting and sump, but it would be a suck it and see situation. I have no idea how much of the motor would need to be stripped to complete this job, but given its proximity t5o the crank I'd say its a bottom end tear down.
With the SX4 sump, this won't fit a vitara, and I'd guess its not much better for a sierra that doesn't have SPOA.
Post Posted: Wed Mar 20, 2013 10:34 pm
The oil pump is exactly the same, just oil pick up and sump & oil pickup stick.
eg.
http://flickrhivemind.net/User/JARYphoto/Interesting
http://www.flickr.com/photos/79046994@N00/3976051746
http://www.flickr.com/photos/79046994@N00/3976051842
http://www.flickr.com/photos/79046994@N00/3976051972
Post Posted: Thu Mar 21, 2013 12:09 am
datso wrote:
What is all this stuff for? Are these pics of a vit/ GV J20? Or are the supposed to be the SX4 J20?
Post Posted: Thu Mar 21, 2013 10:21 am
sold now
Post Posted: Fri Apr 05, 2013 9:28 am
sold now
Post Posted: Sat Apr 06, 2013 2:43 pm
conversion done to sierra by NSW owner
http://www.suzuki4wd.com.au/forumvb/sho ... A-for-sale
Post Posted: Sat Apr 06, 2013 3:25 pm
i'm guessing it would have been out of a SV or SQ rather than a SX4, but it doesn't say. :?
trying to find the bits to convert it to rear sump etc might be hard to get without buying a motor. do these things run a cam position sensor at the rear of the head on the LHS like the SV & SQ's?
Post Posted: Sat Apr 06, 2013 6:50 pm
sold now
Post Posted: Sun Apr 14, 2013 1:14 pm
sold now
Post Posted: Sat Apr 20, 2013 11:55 am
sold now
Post Posted: Mon Apr 22, 2013 7:00 am
Will this bolt directly into my 2000 GV do you know? I have valve noise and a couple of gremlins that are going to take alot of time to fix and might be easier to just take the bare motor and bolt all my early gv electronics and shit to it and drop it back in then rebuild teh orginal motor with some go fast bits :D If it wil drop straight in i will take it this week :D
Dave
Post Posted: Mon Apr 22, 2013 11:26 pm
sold now
Post Posted: Tue Jul 23, 2013 1:22 pm
sold now
Post Posted: Mon Oct 21, 2013 12:45 am
sold now
Vehicle: 2005 Grand Vitara
Post Posted: Thu Nov 14, 2013 10:51 am
Hi do you still have the engine?
Post Posted: Mon Nov 18, 2013 12:01 pm
Adam called you and left a message, I also have as mentioned I think earlier I have a complete J18 engine from a gtx baleno that was crashed but kept for interchangeability and spare head for porting in case I built a hotty later on.
Post Posted: Thu Nov 21, 2013 11:19 pm
sold now to Adam
Users browsing this forum: No registered users and 125 guests
