It is currently Mon Nov 02, 2026 7:21 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
Vehicle: 2006 M18A VVT auto Jimny
Post Posted: Sun Mar 10, 2013 8:44 am
Top
Reason for selling: to cut a long story short I was certain, due to a under car issue that my transfer had stretched the chain. I put a replacement in and the problem remains as something else that I'm still trying to determine.
Cost: $400
Will consider assistance with postage.
Pm me.
Cheers.
Post Posted: Sun Mar 10, 2013 10:57 am
Top
i wonder what kind of revs this will give me with 215's on the high way.
would it change low range gearing or would it stay the same?
Post Posted: Sun Mar 10, 2013 5:21 pm
Top
SO is the chain slipping? Did you replace the chain or the entire transfer case?
Which one are you selling? Original or replacement - Is it new or second hand?
Post Posted: Sun Mar 10, 2013 6:25 pm
Top
No the chain isn't slipping. The transfer case for sale is the original electronic out of my 06. I put a complete newer model in and I ain't changing it back. I still have the problem which looks like auto shaft now as the problem is a rattly vibration on power and is still doing it even with the newly installed case. If I was selling the newer one I'll be asking more than $400 as its out of an 12 model with 8000kms.
Post Posted: Tue Mar 12, 2013 12:34 pm
Top
I had the rear tail shaft CV start skipping on me a while back. Turns out it there was a dent in each mid section of the birfield and the balls just came addrift.
I reckon by installing a shaft spacer, that would change the running position of the balls. Maybe you have just lost one ball.
Post Posted: Tue Mar 12, 2013 12:39 pm
Top
The electronic jimnys change the low ratio exactly the same amount as the high ratio.
M/T high 1:1 low 2:1
A/T high 1.27:1 low 2.54:1
On 215's your revs will be well over 4,000 at 10k's.
Do some calcs here... http://www.grimmjeeper.com/gears.html
I have the gearbox ratios if you don't.
Post Posted: Tue Mar 12, 2013 4:26 pm
Top
Finally got it sorted today. Turned out it was the auto shaft uni as it comes out of the gearbox. It had collapsed and seized in one plane. Was hard to see and assess as it was behind the mount. I didn't pull the shaft right out and assess when I changed the transfer. The symptoms were of everything described by people with transfer chain problems.
Problem is I'm stuck with the transfer I bought hence the sale of my old one.
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Mar 13, 2013 3:07 pm
Top
You have a pm
Post Posted: Sat Mar 23, 2013 9:34 pm
Top
Bump
$350
Post Posted: Sun Apr 07, 2013 7:37 pm
Top
Bump $300.
Vehicle: stock
Post Posted: Sun Apr 07, 2013 8:37 pm
Top
Pm sent
Post Posted: Wed Apr 10, 2013 7:31 pm
Top
## SOLD ##
Users browsing this forum: No registered users and 35 guests
