| Santos's bits and bobs [SYD] http://auszookers.com/forum/viewtopic.php?f=7&t=40376 |
Page 1 of 2 |
| Author: | Santos [ Fri Apr 19, 2013 12:41 am ] |
| Post subject: | Santos's bits and bobs [SYD] |
COLEMAN Dual fuel Lantern with original box $35 Probably only used once in since new, approx 15 years old, runs on petrol or coleman fuel (turps) still has $125 price tag on retail box and has a packet of gas mantles COLEMAN Dual fuel twin burner stove $75 Clean, near new nly used a handful of imes. Petrol/Coleman fuel ---- 80L Lemair mini fridge $50 (twin crisper suit single bachelor or as a bar fridge) New 800w Inverter (used less than 5 minutes Modified sinewave) $50 posted australia wide ------ NEW/NOS G13 8v STD 74mm Flat top pistons NO RINGS (4x) $40 posted (can include used sierra rods with extra used pistons $10) ---- Update. I have 4 G13 8v heads and 3 engine blocks (1x G13A, 1x G13BA, 1x G13B)I you need any components or parts (eg rods, valves, complete heads, bare block etc ) for 8v 1.3L shoot me a PM. They are free providing you pick it up or pay for postage i can't bare to scrap useful parts. The exception is the g13b forged crank which will need machining but is $20 ---------- Suzuki baleno multi-rib altenator, 55A (suit g16 engines) $20 Suzuki Vitara V6 LWB Disc/rotors to suit 16" wheel $100 --> NOW $80 ---- 140A Cigweld stick welder $60 including 20 weld rods (needs electrode holder which are $15 on ebay or at bunnings, can supply a new Cigweld one for $36) ![]() --- 2x black ninja swords $35 for the pair plus post --- ---- Pick up northern beaches, sydney. Post at buyers expense (3kg prepaid satchel?) Seth 0414810942 or PM me here |
| Author: | Santos [ Wed Apr 24, 2013 11:01 am ] |
| Post subject: | Re: Inductive Timing Light, Suzuki baleno altenator $25 [SYD |
bump, added timing light ($25 posted) |
| Author: | Santos [ Thu Apr 25, 2013 5:29 pm ] |
| Post subject: | Re: Santos's bits and bobs [SYD] |
merge my stray items, will be adding to it rather than starting new threads all the time |
| Author: | Santos [ Thu Apr 25, 2013 5:49 pm ] |
timing light, dwell tacho, compression gauge sold pending payment. If you where interested in it just send me a pm and i will put you in queue if falls through. |
| Author: | Santos [ Thu Apr 25, 2013 6:12 pm ] |
added the 2nd largest swiss army knife in the world, the largest is the Wenger Giant. |
| Author: | Santos [ Tue May 07, 2013 6:30 pm ] |
XAVT now on ebay http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 843wt_1137 140A Cigweld welder with 20welding rods $65 needs electrode holder, can supply one to test unit. |
| Author: | Santos [ Thu May 23, 2013 11:02 am ] |
added v6 vit brakes |
| Author: | Santos [ Fri Jun 21, 2013 5:41 pm ] |
Added: Genuine Maglite with Led Upgrade. Gives a nice clean white light, has spare incadescent in the buttstock which you will probably never need since the led is rated 20 000 hrs. Takes 2x C size batteries. Recommend you get the AA->C batteries adaptor off ebay so you can just use AA rechargeables. With 2xAA 2000mah in adaptors i have got a recorded 27 hours run time... much better than the factory 3 hour weak light incadescent! $22 posted australia wide |
| Author: | Santos [ Sat Jun 22, 2013 6:11 pm ] |
Added: Snap-on Gm70M 1/4" ratchet + 2 extension bars (150mm + 50mm) $35 posted australia wide |
| Author: | Santos [ Fri Jul 05, 2013 7:33 pm ] |
G13/g16 8v sports exhaust system. Complete Extractors+Catconverter+muffler to suit Sierra 1.3l models (fits both 1.3/1.6l engines) $100. Cheaper than getting just the extractor neew on ebay.. less mucking around just bolt in!
| Author: | Santos [ Sat Jul 20, 2013 3:08 pm ] |
Added 12v battery charger (mains 240v) |
| Author: | Santos [ Sat Jul 20, 2013 4:14 pm ] |
added photos of exhaust system |
| Author: | camskea [ Sun Jul 21, 2013 9:30 am ] |
Any chance of posting the exhaust+extractors to 3109 melbourne |
| Author: | Santos [ Sun Jul 21, 2013 1:10 pm ] |
camskea wrote: Any chance of posting the exhaust+extractors to 3109 melbourne Find a freight depot that is within 10kms of brookvale, Sydney nsw 2100 and I will drop it off to them if their quote works out for you. Haven't got time to do the leg work myself. |
| Author: | camskea [ Sun Jul 21, 2013 2:03 pm ] |
I'll do some ringing. Can you give me the weight and approx length of the separated pieces? It does fit a 1.6 vitara right? |
1.6 carby vitara...? |
| Author: | Scrawny [ Sun Jul 21, 2013 5:26 pm ] |
camskea wrote: 1.6 carby vitara...? Yes, it will fit yours |
| Author: | Scrawny [ Sun Jul 21, 2013 5:28 pm ] |
Awaiting pm reply too Santos |
| Author: | Santos [ Sun Jul 21, 2013 5:43 pm ] |
camskea wrote: I'll do some ringing. Can you give me the weight and approx length of the separated pieces? It does fit a 1.6 vitara right? Its welded all in one piece. The extractors would fit a vitara. If I cut it up you could probably reuse the all parts to make an exhaust system with new pipe that will suit a vitara. If that's your intention I will go get the measuring tape. As one piece now I have no idea if it would line up under a vitara Scrawn wrote: Awaiting pm reply too Santos Yeah just need to get my camera and stuff, thought I send you some 'extra' photos of stuff. |
| Author: | Scrawny [ Sun Jul 21, 2013 5:53 pm ] |
Santos wrote: As one piece now I have no idea if it would line up under a vitara It'll have no chance of fitting a Vit as it is. Better off just sending extractors, cat and muffler |
| Author: | Santos [ Sun Jul 21, 2013 6:59 pm ] |
Rough measurements final value is thickness and are estimates Extractors 60cmx60cm x20cm Muffler 60cm x25cmx 25cm Cat-converter 35cmx20cmx20cm If I cut it up I could probably fit it in a box that will go through auspost. $52.30 is the biggest box with 20kg using online estimator. The max they will post. I don't think It will weigh that much but I can stand on scales tomorrow holding it to get the weight. |
| Author: | Santos [ Wed Jul 24, 2013 11:21 am ] |
added spring bush kit Snapon-1/4ratchet+bars & 3d Maglite SOLD |
| Author: | camskea [ Wed Jul 24, 2013 12:18 pm ] |
Would you sell the extractors separetly ? |
| Author: | Santos [ Wed Jul 24, 2013 2:59 pm ] |
camskea wrote: Would you sell the extractors separetly ? sure $80 and I will cut it for free
| Author: | Santos [ Thu Jul 25, 2013 3:31 pm ] |
added photo of Stick welder |
| Author: | Blkzuk [ Fri Jul 26, 2013 9:37 pm ] |
Hi santos I'll get the battery charger off ya if you still got it Cheers mate |
| Author: | Santos [ Sat Jul 27, 2013 6:05 pm ] |
complete 8v sport exhaust system sold. |
| Author: | Blkzuk [ Tue Jul 30, 2013 4:27 pm ] |
Pm sent |
| Author: | Santos [ Sat Aug 17, 2013 3:47 pm ] |
bump ADDED FREE STUFF |
| Author: | Santos [ Tue Aug 20, 2013 9:57 pm ] |
new old stock pistons + rings $80posted |
