It is currently Sat Oct 17, 2026 6:25 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
Vehicle: Sierra 1990
Post Posted: Tue Apr 30, 2013 12:39 pm
Top
More photos as promised on official carsales add (couldnt upload them properly here)
http://www.carsales.com.au/private/deta ... 0803/?Cr=0
Auszookers discount price (as listed here) still applies, just mention that you are a member if you contact me through carsales
Hi all,
its a sad day for me but its time to start putting some feelers out to see if there is any interest in my little beastie. With my FIFO job up in northern Queensland, 3 regos to my name and my other Sydney based car project coming to completion in the coming month or two I just dont see how i can be justified in holding onto her...there must be someone that will love her as much as i have
She has been my pride and joy for over 8 years now and i bought it as a pretty much stock little 4wd and slowly built her into an unstoppable and very capable 4wd. The majority of the work - engine conversion & wiring + SPOA conversion + rockhopper gears/transfer case rebuild has been done by none other than Wayne Murphy of the MadFab team that some of you might know from the Tuff Trucks scene. There isn't anywhere that the big diesel and V8s go that this little car cant and in worse case scenarios and you get stuck the shear size of the car means a couple of people can lift the thing! Thousands of $ have gone into her and countless hours of my and my many mechanic mates time have gone into this little beast. With the engine conversion she has plenty of 'Ommpf', is a super fun car to drive and is a real head turner. With detachable windscreen, roof and doors it is also a perfect summer or shooting car.
I will officially list this on car sales in the next month (and for an little extra on the price tag) but obviously I would prefer it go to a suzuki loving home hence why i am starting here. If anyone knows of anyone that is looking for one of these please pass the word on. Soon (when i return to Sydney next) i will upload some more photos but here are a couple that i currently have on my laptop
Cheers and Enjoy
Alexei
SUZUKI SIERRA 1990
2 Door, 4 Seater, Manual – Mini, mud loving monster truck
Rego:
Till mid october
Kilometers:
203000 on the body with 140000 on the engine
Modifications:
MECHANICAL
1.6L EFI conversion (vitara bottom end, vitara cams, baleno inlet+head, modified dizzy, vitara angled drive, vitara computer)
New head – less than 7000km ago (dropped a valve while 4wd in the Blue Mountains a couple months back and got the whole thing overhauled)
Custom built 3 core radiator and Italian thermo fan mounted on radiator – keeps the engine cool as with as much mud as you can throw at it
Custom built extractors to high flow cat and sports exhaust system
Suzisport 8.8mm leads
SUSPENSION/DRIVE LINE
2.5” Suspension lift
2” Solid Aluminium body lift
Snake racing SPOA conversion including – High steer knuckle, ADR braided brake lines, Rock rod, 2 x 13mm Aluminium drive shaft spacers, 4 spring perches professionally welded to axles
Snake racing 2.5” extended shackles (greasable)
6:1 reduction gears with a huge 215% reduction in low range and 20% reduction in high range – these were put in 20000km ago with complete overhaul of transfer case including new and strengthened bearings – ratio'ed to run 33 inch wheels
BODY + OTHER
ARB bull bar
LED light bar – pencil beam
Custom red-blue paint job
New soft top – with 9 months of the 1 year warranty remaining
Swift GTI (recaro) front seats – 2 standard back seats removed, but will refit for sale
Basically brand new 32x11.5” Cooper Discover mud terrains fitted to new black powder coated King wheels (95% tread remaining)
2.5 inch rubber flares to cover the big wheels
Ratio box for speedo – Speed calibrated for big wheels, peace of mind with speed cameras/traps
Front and rear diff breathers
CB radio with long range antenna – fitted at rear for the remote controlled buggy look
VN commodore EFI fuel pump with mini “surge” tank set up (this is to overcome the fact that the fuel tank is designed for a carby not EFI engine)
CD player with 2 speakers in the rear
Sealed computer box
6 month old battery
Aluminium roll bar
OTHER THINGS TO COME WITH CAR
4 x 30” muddies (20 – 25% tread remaining)
5 tonne farm jack
Additional Information:
Now because i am such a fanatic about my car and i really am a 'do to others as you would have done to you' type of person here is a list of things that i have done in the last 2 "off swings" from my work up in north queensland to get the car 110% mechanically A1. I am not the type of person to sell a lemon and am a very upfront about any issues or problems.
New front main seal plate, new main oil seal, re-sealed sump, new engine oil and oil filter
New engine mounts x 2, new gear box mount
New input gear shaft seal plus new gear box oil
2nd hand steering box
New main thrust spring and gear selector bush
Price Range:
$5000 but open to neg - (reduced price expires this October)
Contact:
PM here - or email might be the go - alexeinicholls@hotmail.com
Car is located on northern beaches, Sydney. Come have a drive and fall in love with her as i did many years ago.
Post Posted: Mon Jun 10, 2013 12:17 pm
Top
bump it up
Post Posted: Fri Jun 14, 2013 5:32 pm
Top
Post Posted: Thu Jun 27, 2013 8:36 am
Top
b b b bumppppptyyyyyy
Post Posted: Thu Jun 27, 2013 11:03 am
Top
There is no way that it weighs 700kg. Minimum would be 1200kg
Post Posted: Thu Jul 04, 2013 11:38 am
Top
Fixed just for shep
Bummptyyy
Post Posted: Sun Jul 07, 2013 6:58 am
Top
price drop - come get a bargain!!!!!! (expires in October)
Post Posted: Tue Jul 16, 2013 2:59 pm
Top
Bump diggity
Post Posted: Mon Jul 22, 2013 12:07 pm
Top
anyone??
Post Posted: Mon Jul 22, 2013 12:33 pm
Top
pretty sure most would be put off by the 2.5" lift, 2.5" shackles, SPOA + 2" bodylift.
Post Posted: Mon Jul 22, 2013 12:53 pm
Top
how so? the only thing i would really change on this set up is remove the body lift which isnt really needed and lifts the cars centre of gravity.
that being said ive never rolled the car in the 8 years i have owned it and have been 4wheeling heaps
Post Posted: Wed Jul 31, 2013 8:59 pm
Top
Bumpy mc scrumpy
Post Posted: Wed Aug 07, 2013 8:54 am
Top
Considering Rego is due in 2 months and 2 days its time to price this thing to sell.
I want to avoid having to put another 6 months rego on a car i barley have time to use these days (not to mention my original goal is to reduce the number of rego'ed vehicles i own)
New Price of $5000
My loss...your gain
Vehicle: 1989 hard top
Post Posted: Wed Aug 07, 2013 11:16 pm
Top
Goodluck with the sale mate
Post Posted: Thu Aug 08, 2013 3:19 pm
Top
Car is regretfully SOLD via carsales.
Thanks to all the interest
Users browsing this forum: No registered users and 70 guests
