It is currently Mon Nov 02, 2026 9:23 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
Post Posted: Fri May 10, 2013 3:33 pm
Top
ITEM: Sierra Comp Truck/Truggy
Price: $20,000
CONDITION: Like new, has been driven for about 10 minutes to test everything is working as it should
REASON FOR SELLING: Change of plans
CONTACT: PM
INFO:
Driveline
  • VR Commodore V6
  • 4L60E Gearbox
  • Hilux Transfer
  • Trail Gear Twin Sticks
  • 2 Piece Front Shaft
Diffs
  • 4.8 hilux, braced housings
  • Air lockers front and rear
  • Trail Gear six shooter knuckles with ARP studs
  • New seals, gaskets and bearings, Trail gear rock rings and wiper seals
  • Breathers run into cab
Suspension
  • Front and rear 4 link
  • Heim joints on all links
  • Fox air shocks, 16" front 18" rear
  • Front and rear suspension winches
  • Front set up for hydraulic bumpstops with poly performance bumpstops fitted
Steering/Fuel
  • Trail Gear full hydraulic steering with double ended ram, PSC pulley
  • 40L fuel cell, surge tank and twin pumps
  • Braided fuel lines and AN fittings
Brakes
  • Rear converted to disc's with 75 series calipers and vented rotors
  • Front vented rotors
  • Hilux brake booster and master cylinder
  • Braided Brake lines
  • Hydraulic handbrake
Wheels
  • 37" Comp spec sticky treps
  • 16" Steel rocktoy beadlocks with offroad boss inner strengthening ring
  • Wheel spacers all round
Other Info
  • Tigerz11 10,000lb High-speed series front winch, 4000lb rear winch
  • 175mm Spotlights, 10" LED lightbar, Led tail lights
  • Rear mounted radiator, Stainless piping and silicone joints, thermo and alloy shroud
  • Davies craig alloy auxiliary water pump
  • Racing seats and harnesses
  • Removable tunnel allowing access to gearbox/transfer
  • Grant steering wheel
PICTURES:
Post Posted: Mon May 13, 2013 9:31 am
Top
Good looking rig, best of luck with the sale.
Post Posted: Tue May 14, 2013 10:17 pm
Top
SOLD.
Users browsing this forum: No registered users and 30 guests
