http://auszookers.com/forum/
Modded Warn hi mount
http://auszookers.com/forum/viewtopic.php?f=7&t=41574
Author:  mistaboz [ Mon Jun 24, 2013 2:34 pm ]
Post subject:  Modded Warn hi mount
For sale is my Warn hi mount winch.
All work done by Mal Leslie.
6hp motor with breather and coated internals to stop corrosion (motor approx 12 months old)
Breather on gearbox housing.
Oil fill and drain plugs.
Brace bars x2 between end plate and main housing.
Brake shaft tapped and bolted to prevent circlip coming off.
Free spool pinned to eliminate disengagement under big loads.
Had full service kit and seals approx 1.5 years ago.
Anodized aluminium fairlead (in new condition)
Genuine Albright solenoid.
x4 mounting bolts and nuts supplied.
Battery cables can be supplied if required with proper hex crimped terminals.
Providing you have a descent battery setup this winch pulls like a train. I have never been able to stall the motor or needed a double line pull regardless of the situation.
Does not come with rope however I can supply used cable.
Sold pending payment.
I can supply 40m of Supermax 10mm rope for an extra $400. This has been fitted to the drum around 3 weeks ago but never used and never been left out in the weather.
Contact me on here or my mobile 0419 874 654
Cheers,
Paul
Author:  Zoolanda [ Tue Jun 25, 2013 3:46 pm ]
Post subject:  Re: Modded Warn hi mount
Have you got any pics ?
Author:  mistaboz [ Tue Jun 25, 2013 5:45 pm ]
Not on my camera however I have some on my phone.
Either sms me or pm me on here with your mobiel and I an send some through. It's still on the car at the moment so can't get you pictures from every angle.
Cheers,
Paul
Author:  Junior_91 [ Thu Jun 27, 2013 12:39 pm ]
$2350?
Author:  mistaboz [ Thu Jun 27, 2013 5:49 pm ]
Junior_91 wrote:
$2350?
Yes, would you like to buy it?
Author:  Daleyzooker [ Thu Jun 27, 2013 6:16 pm ]
Hahahahaha
Author:  Junior_91 [ Sat Jun 29, 2013 7:43 pm ]
My highly modifed high mount only owes me 3K. So no thanks mate.
Author:  mistaboz [ Sat Jun 29, 2013 8:45 pm ]
No worries.
Move along then pal.
This winch has dragged an 80 series around with ease and I doubt your car would be heavier than that? Either way, some people may not be as fortunate as you to spend close to 3k on a winch. Even a stock standard hi mount (which this is not) is great on any zook, let alone this one which had had all of the weak points sorted (excluding break shaft) which is not an issue unless running 24v.
Cheers,
Paul
Author:  WestVic-Zook [ Wed Jul 03, 2013 4:10 pm ]
put it on ya zook paul, you know you want to :)
Author:  mistaboz [ Wed Jul 03, 2013 4:50 pm ]
Was thinking about it Owen but it's now sold.
