http://auszookers.com/forum/
Danks 4AGE 20valve sierra Now on eBay see last post
http://auszookers.com/forum/viewtopic.php?f=7&t=41816
Page 1 of 2
Author:  dank [ Mon Jul 08, 2013 9:25 pm ]
Post subject:  Danks 4AGE 20valve sierra Now on eBay see last post
Selling to the right owner who will use the zook more than me. Starting another company and just won't have the time to wheel it in the next couple of years. Would be a VERY good comp rig/ basis for AUST4/Ultra4/tough truck style buggy, or get a RWC and keep on wheeling it.
The zook is not engineered for it's mods. Located in Tynong 3813.
88.5 SWB WT Sierra
Front Diff: $2000
GENUINE ARB Airlocker
4.57:1 Yukon Diff Gears
CrMo CVs and Axles
Fully rebuilt swivel Hubs 0km old
Brand new DBA Rotors and Pads 0kms old
Extended wheel stud conversion 0km old
Extended brake lines
80 series progressive rubber bumpstops
Brand new EFS bushes 0km old
diff is straight small dint in the centre cap
EFS 65mm Rears in Front with 60mm RUF conversion $50 the pair one is a little bent
Extended shackles
Rear Diff $1000
Richmond Gear Lockrite Locker
Stock Axles
Low range sierra Disc Brake upgrade
Sierra Front Calipers
Extended Brake line
Inverted Upper Shock Mounts
EFS bushes new
Extended shackles
Brand new EFS 65mm Rear Springs $100 pair
Engine: $1000
1995 model 20 valve 4AGE Silvertop motor
Stock ECU
Thermostat housing Tig welded for RWD conversion
Davis Craig adjustable Mechanical temp sensor to run rear mount radiator
32mm alloy pipe and HD hydaulic flex line to rear mount radiator
dual SPAL 11" Slimline Thermo Fans $100
XJ Jeep Radiator mounted in Tailgate. Tailgate opens seperately from the radiator $100
Davis Craig EWP80 electric water pump. (only used as a backup, not currently being used as motor waterpump is sufficient) $100
1.3 engine mounts remain 10mm adapter plates used with vl commodore rubber mounts
The whole wiring loom was transplanted into the car and runs a more simple relay system to run the fuelling.
This motor and auto will bolt into any other swb 1.3 sierra.
Fuel system: $300
SWB EFI Vitara tank - custom mounts
Custom folded 3mm galvanised plate with closed cell foam load distribution packing. has taken some big hits with no deformation at all.
Internal EFI pump is installed but not wired up, could be faulty replaced with:
running External Bosch 044 EFI pump mounted on the rail where the fuel filter is. Works really well, no probs over 1000km+. Easy to swap over out in the bush, two hose clamps and electrical connectors
return line replaced with same diameter metal line as sender line.
Transfer Case: $700
4.9:1 Trail Tough Reduction gearing
Spidertrax upgraded mounts
50mm transfer lift with machined alloy spacers on compression side and urethane spacer with through bolt conversion on the pull side
Custom made disc handbrake mounted on the back of the transfer. utilising a cable operated gokart caliper and pit bike disc rotor. Will hold the zook on ANY angle if all four wheels are on the ground. freaking awesome mod not affected by mud
Transmission: $1000
A40 Aisin Warner 3 spd auto
80 series torque converter upgrade
Custom valve body mods for harder shift
Clutch pack upgrade from 3 to 7 clutch packs
all brass bushings replaced with japanese roller bearings
Synthetic trans fluid only used
Honda civic old school shifter.
Main shaft upgrade to 80 series shaft
Flex plate bolts upgraded from 6mm to 10mm cap head unbreakos
Has been totally rebuilt, strengthened and upgraded to a point where it is now reliable under heavy punishment
custom length jack shaft
cost $3500 to get to this point
Body: $200
Transmission tunnel widening
Cut front guards (some may say hacked!)
rear guard clearancing
body is free of rust
sills have interesting rock rash ;) I have 1/4inch 90 degree bent plate for sill protectors in the shed for it.
basically every panel has some type of damaged from pin striping from trees to contact with rocks and trees and other zooks. It polishes up nice but it's definitely not a show car. It was built to use
Doors are working, glass is good
comes with full soft top in average condition and bikini top in excellent condition only used three times
HID upgraded headlights
Custom Tube winch bar $200
Front custom F-truck shock mount upgrade.
Shocks are rear Ridepro IFS Hilux Rears, front are GQ 4inch Rears superlift
Three gauges installed in Guage pod above dash, Oil Pressure, Water temp and Auto tranny temp. all 50mm Speco white face gauge.
Volt meter and lap timer installed. $120
Incab winch control installed in dash.
LED Clearance rock lighting mounted on chassis rails under sills with dash switch.
ARB Airlocker compressor. $100
metal tool box in the back
Aldi large compressor with tigerz steel 9 litre tank. air gauge mounted in dash $100
2 inch bodylift justcruizin supplied $50
LED tail lights
LED reverse flood light
powersteering setup $400
vitara box
bent wedge
all lines
reservoir and cap
powersteer pump 4age with mounting bracket
Wheels and tyres:
Tyres 80% swampers LTB 34x10.5-15 $800
KPD Alloy beadlocks $800
8mm spacers $50
Things i'm not selling with the car:
LED Lightbar
Lowmount Winch
UHF and antenna
There are so many things i've done to the car over nearly ten years of ownership its impossible to list everything. It would be great to sell the car complete.
I will part it out if no one is interested in the whole car. in parts as indicated it totals $9290. take the whole thing for $8000 no reg no rwc. the zook will be available as a whole car for pickup until 21st July. I will part it out when i return if no interest when i get back from overseas in early September.
parts wise you get everything for the indicated price under the headings except those items with a price next to them.
Author:  ajsr [ Mon Jul 08, 2013 9:50 pm ]
Post subject:  Re: 20 Valve 4AGE - 3 SPD worked AUTO - SWB 88.5 WT Sierra.
that's a whole lot of car for the $
good luck with the new business dan
Author:  -Dex- [ Tue Jul 09, 2013 2:10 pm ]
Damn, this thing is very cool, sad to see you selling it. Shoot me a PM if your new business is 4wd related. I may be able to help a little. ;)
Author:  dank [ Wed Jul 10, 2013 4:52 pm ]
Thanks AJSR and Dex. New business is not 4wd related, i'll be running it concurrently with KPD4x4 but you may be able to help. I will send a PM soon.
Author:  remydog05 [ Thu Jul 11, 2013 12:13 pm ]
ERR um you sure you know what your doing? Last time you drove it you said your never selling it!!
Just take it to work and coil it!
Author:  charged88 [ Thu Jul 11, 2013 1:44 pm ]
Just sell it to KPD.... hello company vehicle tax offsets lol
Author:  KEENSY85 [ Sat Jul 13, 2013 5:26 am ]
What a rig hope u sell it good luck with the new business
Author:  dank [ Mon Jul 15, 2013 12:39 pm ]
I got sick of waiting for you remydog to finish yours :D. Most likely this will stay with me by the looks of the lack of interest shown in it as a whole vehicle. If I get really keen I'll part it out when I get back in September, but probably won't.
If someone was smart and had $8k kicking round it would be one of the easiest ways to convert your current sierra into a beast without having to spend $25k over 8 years in refining all of the bad bits out of it! All the driveline gear will bolt into a stock 1.3 sierra. Can't get any easier.
With hard tracks getting harder and harder to find to drive legally down my way the zook is not getting the use it was designed for. Right now my zook has just clicked over the 25 year old mark making it eligible for club rego. Interestingly after talking with Allan from Piranha and he just club regoed his Sierra Chassis Vitara bodied Coiled Comp Rig through the Toyota Landcruiser Club of Victoria. I might look into this further.
Author:  dank [ Mon Jul 15, 2013 12:58 pm ]
Leaf springs are where its at! It would cop full coilovers and a wheel base stretch if I ever went down that road, but it would probably be cheaper to buy one of these :rambo: and "finish him!"... phrases like :deadhorse: and you can't polish a turd, but can roll it in glitter come to mind at the mere though of wasting more money on it!
Author:  dank [ Thu Sep 05, 2013 1:32 pm ]
Zook is still for sale, CBF parting it out, it will be sold whole. see first post for price details. nothing has changed there. It's there for the taking!
Author:  Asps91 [ Thu Sep 05, 2013 2:35 pm ]
Damn.... You got some sweet parts there. If you change your mind I'm keen on a few things ;)
Author:  dank [ Thu Sep 05, 2013 3:14 pm ]
:D
Author:  Heideisadog [ Thu Sep 05, 2013 3:48 pm ]
jeezzzz looks great!
Hope it sells mate.
Does it have cup holders? <big selling point right there...
Author:  Built4thrashing [ Sat Sep 07, 2013 9:05 pm ]
Hope it sells mate.
Yes it does...... They are called passengers.
Author:  dank [ Fri Sep 20, 2013 11:09 am ]
number is 0428 292 839 if anyone wants to have a chat about it!
it'll be going on eBay in the next couple of weeks!
Author:  shakes [ Fri Sep 20, 2013 11:40 am ]
still cant talk the missus into this being a solid investment.
A whole lotta car for the money!
Author:  dank [ Fri Sep 20, 2013 3:04 pm ]
Yep someone who is looking to Mod their sierra would be mad not to pick all this gear up for the price advertised. There is so much there easily 10k worth of parts
Author:  dank [ Wed Jan 08, 2014 2:57 pm ]
Ok bumping this back up. $8000 take the whole car plus all the spares I have, Take it all!! EVERYTHING!! winch and UHF/antenna is also including, lightbar has been moved on.
If you are really interested in this rig give me a call on 1300 780 141 and we can talk. I am negotiable with serious buyers. I have a tandem trailer which I can lend or deliver the car on as well dependant on location to the buyer.
All the springs are brand new, the calipers on all 4 wheels have been rebuilt with new brake pads, all new bushes, the swivel hubs, king pins and front wheel bearings are all new and have been redone, the hubs have a long wheel stud conversion which was over $200 in parts alone for the studs!
The car starts first go everytime. The auto is strong running full synthetic nulon ATF. The whole driveline is in excellent condition, don't forget the full fabbed transfer mounted disc handbrake setup which is unreal offroad.
Tyres are about 70% at a guess. Still Heaps of Meat. Anyway, at $8000 it's an absolute bargain. There is a shitload of cool stuff on this zook but its time for it to go! Serious buyers, give me a call.
Author:  dank [ Fri Jan 10, 2014 5:21 pm ]
It's going on eBay this weekend.
Author:  dank [ Wed Jan 15, 2014 5:19 pm ]
Now on eBay: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1425900836
Author:  dank [ Thu Jan 23, 2014 12:36 pm ]
Post subject:  Re: Danks 4AGE 20valve sierra Now on eBay see last post
Back on eBay again. http://www.ebay.com.au/itm/Suzuki-Sierr ... 9db&_uhb=1
Three day auction. I'm chasing $6k as it is which is an absolute steal. If you want to buy it give me a call on 0428 292 839 to discuss.
If I don't get $6k i'll be parting it out.
Dan
Author:  jake84 [ Thu Jan 23, 2014 1:05 pm ]
hey if your going to sell it i would of liked to see pics of motor , under the car and in side instead you have put up pics that are usless for the buyer
your pics depict that you have thrashed it just saying sorry if im sounding like an ass dont mean too
Author:  tanshi [ Thu Jan 23, 2014 1:09 pm ]
your pics depict that you have WHEELED it just saying sorry if im sounding like an ass dont mean too
Fixed, sorry mate but your wrong. any one who is going to buy this thing isnt going to get a shit what the interior is like.
Author:  henno [ Thu Jan 23, 2014 1:10 pm ]
It has an interior?
Author:  Zook_Fan [ Thu Jan 23, 2014 1:31 pm ]
If this was in QLD I would be all over it for that price. Hope it goes well for you Dan.
Author:  tanshi [ Thu Jan 23, 2014 1:32 pm ]
If it was in QLD It would be in my yard :D
Author:  henno [ Thu Jan 23, 2014 1:48 pm ]
If I had a trailer to get it to and from the tracks, this would be in my yard...
... oh, and $6k of course. ;)
Author:  dank [ Thu Jan 23, 2014 2:00 pm ]
Yep you sound like an ass, must be a jimny driver thing. Check out the eBay listing, pics of both the interior and Engine bay.
Author:  gooldin [ Thu Jan 23, 2014 2:02 pm ]
henno wrote:
It has an interior?
WOW...and aint she a nice one!
Author:  dank [ Thu Jan 23, 2014 2:10 pm ]
We actually wheel our zooks down here in Victoria, often in mud, and heck, sometimes we actually get them dirty! Sometimes just for fun we take the doors off as well. just to get that little bit extra dirty. :D
Page 1 of 2 All times are UTC + 9:30 hours
