| Car Parts redundancy package (QLD) http://auszookers.com/forum/viewtopic.php?f=7&t=42296 |
| Author: | Highway-Star [ Sun Aug 04, 2013 6:28 pm ] |
| Post subject: | Car Parts redundancy package (QLD) |
Hello All. Many of of my parts and collection of junk have been made redundant, so please come buy stuff before I dump stuff! Here are the terms and conditions of the redundancy package: Everything is "as is", if you don't like it, don't buy it. Pickup of everything for sale is preferred (pickup near Ipswich, QLD)....preferred to the extent that I am putting a minimum $100 buy before I will bother posting, and buyer still pays postage (This isn't me being captain cranky pants, just I have to go out of my way to post junk, plus I am very busy at the moment). In theory prices are negotiable... how negotiable depends more on practice than theory though. Any questions, reply here or PM me. Want to buy something PM me. Have fun! $200 Stuff: Custom made 5 speed gearbox, to suit and F series engine, though retain LJ style linkage shift. Box was fully rebuilt. Adaptation of linkage shift still not quite finished. See this thread for details and rebuild pictures: viewtopic.php?f=17&t=12322 $100 Stuff: SOLD9500lb TJM Ox electric winch. Inc control box, controller, wire cable and hook. No fairlead. Has impact damage from what appears to be a bolt hitting the front of one of the drum supports. By all means check it out before purchasing it... Pending paymentPair of Mustard coloured LJ50 type 1 front guards. Reasonable condition, passenger guard needs panel beating on the front outer edge (see pictures at the bottom). $50 Stuff: LJ50 & LJ80 Transfer cases. Down to 1x 3:1 ratio, and a few more 2.5:1 ratio. "Dead" ones have all been tossed into the scrap pile, so these are all functional. SJ413 5 speed gearbox, unknown condition, I have 2 of. $20 Stuff: LJ50 steel parcel tray, straight though needs paint. SJ413 Brand new still packaged cork 1.3 tappet cover gasket. 2 SOLDSJ413 1.3 flywheel. I have 2 of, one has a clutch etc in unknown condition. SOLDSJ413 pedal assembly (all 3) with bling aftermarket foot grips, includes bracket for acc ped, and box for brake/clutch peds. Soft vinal spare wheel cover, with Bush ranger and the words "back up!" on it. Excelent condition, fits Standardish Suzuki size wheels (26-27" etc). SOLDOddball Tailshaft. LJ/SJ410 flangers both ends, 2 unis, splined centre. 315mm long closed length. Brand new what I believe is a 1.6 Vitara clutch cable. $10 Stuff: LJ80 plastic parcel tray. Little shabby, but not broken. SOLDLJ/SJ410 flange with stub to slide into the back of a Toyota K series 5 speed box. SJ410 4.1:1 Front differential. SJ413 Handbrake Lever SJ413 pair of Radiator support brackets. SJ413 Fan shrouds. I have 2 of. SJ413 front plastic stone tray thing from under radiator. SOLDSJ413 Soft top hoop SJ413 soft top track from on top of windscreen (with screws) SJ413 Winscreen to targa bar stays. SJ413 complete set of 8 G13 valves, springs etc. Used, but from a low mileage engine and in excelent condition. SJ413 1.3 water pump. Used, but was fine when removed from car at a service interval. SOLDSJ413 Master cylinder and booster. Booster has surface rust, but worked when in vehicle. SJ413 Passenger door handle. SJ413 Transfer case top side bracket. SOLDSJ413 Doors, red, drivers in bad shape (read as large impact). Windows gone... SE416 Auto Transfer case. Appears to be in good condition. Free Stuff: Went for Scrap I have a scrap metal pile of dead transfer case bits, drums brakes and so on building up in the cactus garden (because the stuff is cactus.... get it LJ Transfer cases: ![]() Sierra pedals, flywheel, and stuff: ![]() LJ50 Guards: ![]() Sierra gearboxes: ![]() Diff, transfer mount, oddball tailshaft: ![]() More stuff: ![]() LJ81k car: OK, this one is hard to explain clearly, but I'll try. Basically I want to be rid of an entire Suzuki LJ81k worth of parts. So I am selling a car, but it is not assembled (But I will not sell the individual parts, buy all of it or don't buy it). Exact price is probably best negotiated with the buyer depending on their exact parts requirements, and if they maybe buy other junk off me, but I am looking around the $300-$400 region. Am Currently assembling this, will be heaps more negotiable on price if you want it before I get this done. DO NOT look at this car if you are not prepared for some work; IE if you are only interested in buying a car and bolting on crap, forget it. The chassis is sound and with some minor tidy up would be ready to rock. The body and driveline however will need work, and some genuine enthusiasm. For an indication of the level of work required on the body, look at my build thread, I did similar amounts of rust repairs, bonnet bashing and guard building etc on my LJ80 for the first half of this year: viewtopic.php?f=4&t=9557&start=573 I have not yet found all the parts for a complete car, as I am in the middle of a tidy up, and still have one and a half sheds to go. So far I have aside the chassis, the cab, front guards, front panel, bonnet, doors, F8 engine, 4 speed box, transfer case, all tailshafts, rear diff assembly, not quite all the front diff assembly, all the steering assembly, fuel tank, radiator and other bits. Known missing bits are front hubs, seats (I have head rests though), a tray, wheels and tyres, plastic grill, and some bits and bobs. As previously mentioned though, negotiate with me with what you need, and we may be able to work something out... ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for reading my huge ad! |
| Author: | Dcraw [ Sun Aug 04, 2013 7:01 pm ] |
| Post subject: | Re: Car Parts redundancy package (QLD) |
Hi mate, Does the tjm winch work and if so does it need any other parts? Does the damaged drum support need to be replaced to be used? Cheers |
| Author: | Highway-Star [ Sun Aug 04, 2013 7:12 pm ] |
Dcraw wrote: Hi mate, Does the tjm winch work and if so does it need any other parts? Does the damaged drum support need to be replaced to be used? Cheers I don't know if it works. I don't know how it is supposed to be wired up, so haven't tried. If you want to bring a battery with you and try it, go for it. Replacing the part would be ideal. As it stands I don't see it preventing operation, though it may have weakened the support. I thought the photo I took showed the damaged bit, but it seems the red cable hanging in front of it obscured the damaged bit... |
| Author: | ZookFan [ Mon Aug 05, 2013 8:36 am ] |
G'day mate I would be keen on the LJ81 fuel tank, how much?? |
| Author: | Junior_91 [ Mon Aug 05, 2013 12:12 pm ] |
Hey Aaron ill grab that winch if its still there! |
| Author: | Highway-Star [ Mon Aug 05, 2013 4:13 pm ] |
ZookFan wrote: G'day mate I would be keen on the LJ81 fuel tank, how much?? Check the ad again Indy, comes with a whole car Junior_91 wrote: Hey Aaron ill grab that winch if its still there! Got a probable buyer. I'll let you know Saturday if he decides to opt out. |
| Author: | Junior_91 [ Mon Aug 05, 2013 6:25 pm ] |
Cheers mate |
| Author: | Wrinkledbits [ Mon Aug 05, 2013 6:50 pm ] |
how much is on the lj81 cab |
| Author: | tanshi [ Mon Aug 05, 2013 7:19 pm ] |
Its the whole ute. He isnt parting it out |
| Author: | ZookFan [ Mon Aug 05, 2013 7:55 pm ] |
How much do you want for whole lj81 then mate |
| Author: | mrw82 [ Mon Aug 05, 2013 8:23 pm ] |
As per the ad $3-400 |
| Author: | Highway-Star [ Mon Aug 05, 2013 10:52 pm ] |
Original ad edited slightly. That LJ81 is going as a "whole package", though dissembled if that makes sense. I will not sell pieces of it... for anyone. Basically I need some room, I don't need 5 cars, and I'd rather see the car go to someone who will do something positive with what to me is a pile of spare parts, rather than see them rust away in my yard. If your serious about it, message me. |
| Author: | Highway-Star [ Sun Aug 11, 2013 7:14 am ] |
Bump. and edit for stuff sold. |
| Author: | tonyevans [ Sun Aug 11, 2013 10:52 am ] |
G'Day Mr.Star I need this thing if it will fit in the Auto box? - LJ/SJ410 flange with stub to slide into the back of a Toyota K series 5 speed box Will you post? |
| Author: | Highway-Star [ Sun Aug 11, 2013 12:57 pm ] |
tonyevans wrote: G'Day Mr.Star I need this thing if it will fit in the Auto box? - LJ/SJ410 flange with stub to slide into the back of a Toyota K series 5 speed box Will you post? Into the back of a K series auto? I don't know. It'll fit a 20 spline, ~22mm shaft if that helps. If that sounds useful PM me, and we'll discuss posting it. I'm on and off busy at the moment, so it could take me a while to do so. |
| Author: | Highway-Star [ Fri Aug 23, 2013 7:51 pm ] |
Bump!!! 2 things: I should hopefully get the box trailer back in 2 weeks, when it returns scrap metal run will be prioritised! Secondly; I am actively job hunting at the moment, and am also looking interstate. Stuff will have to go if I have to move!!! So make me offers, and come take stuff! |
| Author: | mrgtt34 [ Sat Aug 24, 2013 12:39 pm ] |
Got the doors still ? Condition and price |
| Author: | matth27 [ Sat Aug 24, 2013 12:55 pm ] |
Still got drums? and do you have any shoes? |
| Author: | Highway-Star [ Sat Aug 24, 2013 2:32 pm ] |
mrgtt34 wrote: Got the doors still ? Condition and price Doors are here still. Passenger isn't bad, but has some minor dints, and no rust to my knowledge. Drivers as per ad is bad, and has had a large impact, could be bashed straight by someone with panel beating skills and some time and patience. Also has some rust in the bottom. $10 for the pair if you want to come grab them. matth27 wrote: Still got drums? and do you have any shoes? What model drums? I might have both, depends what model drums you need. |
| Author: | mrgtt34 [ Sat Aug 24, 2013 4:23 pm ] |
Yeah ill grab em let me no a time anytime tomorrow is good ! |
| Author: | Highway-Star [ Sat Aug 24, 2013 4:58 pm ] |
You have a PM |
| Author: | 11_evl [ Thu Sep 05, 2013 7:58 pm ] |
Any of this stuff suit buggy? |
| Author: | tanshi [ Fri Sep 06, 2013 8:16 am ] |
depends what a buggy is built from |
| Author: | 11_evl [ Fri Sep 06, 2013 8:59 am ] |
Just a mate is looking to build a buggy so looking to cut up something. Obviously not too good or too rusty, at least not rusty in the main bits. After something cheap |
Yes looking LJ?? Based |
| Author: | tanshi [ Fri Sep 06, 2013 9:07 am ] |
he has a complete lj81 in pieces, :LJ81k car: OK, this one is hard to explain clearly, but I'll try. Basically I want to be rid of an entire Suzuki LJ81k worth of parts. So I am selling a car, but it is not assembled (But I will not sell the individual parts, buy all of it or don't buy it). Exact price is probably best negotiated with the buyer depending on their exact parts requirements, and if they maybe buy other junk off me, but I am looking around the $300-$400 region. DO NOT look at this car if you are not prepared for some work; IE if you are only interested in buying a car and bolting on crap, forget it. The chassis is sound and with some minor tidy up would be ready to rock. The body and driveline however will need work, and some genuine enthusiasm. For an indication of the level of work required on the body, look at my build thread, I did similar amounts of rust repairs, bonnet bashing and guard building etc on my LJ80 for the first half of this year: viewtopic.php?f=4&t=9557&start=573 I have not yet found all the parts for a complete car, as I am in the middle of a tidy up, and still have one and a half sheds to go. So far I have aside the chassis, the cab, front guards, front panel, bonnet, doors, F8 engine, 4 speed box, transfer case, all tailshafts, rear diff assembly, not quite all the front diff assembly, all the steering assembly, fuel tank, radiator and other bits. Known missing bits are front hubs, seats (I have head rests though), a tray, wheels and tyres, plastic grill, and some bits and bobs. As previously mentioned though, negotiate with me with what you need, and we may be able to work something out... |
| Author: | Ragtop [ Wed Oct 30, 2013 8:35 pm ] |
Hello Do you still have the LJ50 guards please? John |
| Author: | Highway-Star [ Thu Oct 31, 2013 8:45 pm ] |
Yes still here. |
| Author: | Ragtop [ Thu Oct 31, 2013 8:58 pm ] |
I'll take them if I can arrange a courier to pickup or possibly you could drop of at a depot, no hurry required. Is there a phone number I may call to arrange please? John |
| Author: | Highway-Star [ Fri Nov 01, 2013 6:26 am ] |
People have replies to PM's. Have also updated the ad a bit... |
