It is currently Fri Nov 13, 2026 10:14 pm
Vehicle: 92 Suzuki Sierra
Post Posted: Wed Sep 04, 2013 7:56 pm
Thought i put this one outside of Santos bits & Bobs as it needs explanation
Multirib Crank and Water pump Pulleys for Sierra 1.3l Alternator / Power steering/ Endless Air upgrades
These pulleys suit replacing the stock V-pulleys on sierra engines with square-tooth timing belts.
The 4swift crank pulley takes 3 RIB belts and the waterpump pulley is actually from a daihatsu charade. Bolting these in they 100% line up with one another and sit in the same spot as the original v belts so you can just swap the pulley on the stock alternator if you are planning Powersteering/aircon/endless air compressor etc.
I can't tell you which alternator bolts in but there are many many many threads covering the subject
you can see by photo no2 there is a difference in crank cogs over the various g13 motors. the bigger one is a 5 bolt pattern (gti/ late model swifts/ vitaras) with round-tooth timing belt. I haven't got any round tooth 4 bolt cogs to confirm size.
If you bolt these two pulleys on the the thicker cogs they will not line up as the crank pulley will be further forward. (strangely in the forwrd position the vitara pulley i have doesn't quite work either witht the 4 bolt pulley but does with the 5 bolt)
Price? $35 posted australia wide (providing they weigh 3kgs or less, will confrm tomorrow)
[/img]
Post Posted: Fri Sep 06, 2013 4:55 pm
$30 posted or $15 pick up
Post Posted: Sun Sep 08, 2013 2:05 pm
PM'd...
Post Posted: Mon Sep 09, 2013 8:26 pm
sold one set,
have a second complete set i found when sorting out garage (last one for sure)
Vehicle: 89 suzuki sierra sj50 g13a
Post Posted: Wed Aug 12, 2015 11:23 am
Can the factory fan be used with these
Vehicle: Drover pickup turk
Post Posted: Wed Aug 12, 2015 11:33 am
Yes it can.
I like the tuna here
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Wed Aug 12, 2015 9:18 pm
Pm'd you Santos
Vehicle: 1984 Sierra
Post Posted: Wed Apr 13, 2016 2:24 pm
Can anyone help me find where to find these type of pulleys. I'm in despreate need of them and cannot for the life of me find the on the net.
Can anyone tell me what model charade they are off because I can only find v belts
Users browsing this forum: No registered users and 24 guests
