http://auszookers.com/forum/
FS: 2006 M18A VVT auto Jimny - Must Sell
http://auszookers.com/forum/viewtopic.php?f=7&t=43202
Page 1 of 2
Author:  Docka83 [ Mon Sep 30, 2013 1:14 pm ]
Post subject:  FS: 2006 M18A VVT auto Jimny - Must Sell
Hey guys,
Long story short, due to losing my job last Wednesday (thanks Abbott) I need to sell my Jimny and other toys. Its had a lot of money spent on it. Made some changes with a top mount trans cooler setup. It had 2 occasions where it spat the coolant out the expansion tank from extended highway driving on hot days. I fixed up some airflow issues i.e. moved the trans cooler/spotlights from in front of the radiator/condenser and it hasn't done it since. Also carried out compression test, teekay test, cooling system pressure test, which all were ok. Also carried out full cooling system overhaul as detailed below.
- white Z Series factory auto
- 175000 km's on body and auto
- liana M18 conversion about 18 months ago with 49,000 km's on motor. Have done about 22,000 on motor since conversion
- 15x7 black sunnies with Geotrac A/Ts about 75% tread and brand new spare
- cold aircon
- Sony HU with full bluetooth capability
- upgraded speakers front and rear with Fusion amp and small home hi-fi sub
- canvas seat covers
- Jimnybits 3" lift with ES1000 shocks
- Toughdog adjustable panhards
- rear shock relocation brackets
- 25mm spring spacers in front for bullbar
- tinted windows
- rear diff bearings replaced last year - centre in good condition
Jimnybits castor corrected radius arms
- ARB winch bar
- Jimny snorkel
- Tigerz 11 12000 winch with dyneema rope/remote control etc
- Custom dual battery system with large AC Delco 97AH for winch and accessories. Winch has engine bay mounted isolation switch/key
- AVM free wheeling hubs
- TD RTC steering dampner
- Uniden UHF
- major service about 8 months ago - swivel hubs fully rebuilt with Jimnybits shims seals etc, transmission oil, diff, transfer, engine oils, filters etc. Car is serviced every 5000kms
- Transfer out of auto 2012 model - ended up being waste of time as symptoms/problem was stuffed jackshaft uni which was replaced
- Jimnybits HD transfer case mounts and bushes
- Genuine Suzuki towbar (uprated model)
Recently done:
- New Great White LED light bar
- OBDII Bluetooth adaptor fitted for use with Torque App
- Rear gearbox seal
- rebuilt rear uni
- balanced jack shaft
- New front rotors and new bendix pads
- Radiator removed, rodded and flushed
- New Radiator fan clutch
- New hoses, thermostat, rad cap and coolant
- Custom front air duct under bullbar.
- Inlet and exhaust manifold gaskets
- Rocker cover gasket
- New waterpump
- New top mount trans cooler setup with IP55 rated fans and gauge in the cabin
- Trans service
Other bits included:
- 2 sets of new extended brake lines
- rear shock sliders (to fit)
- spare parts
- Other stuff I've probably forgotten
Things needed for RWC:
- Mod plate for donk. Easy to do just haven't had time
- windscreen washer reservoir remounted (easy to do)
- Rear diff pinion seal leaking
Have receipts for pretty much everything. Has a few scratches and small dents. Could do with a good cut and polish
Selling unregistered $6500ono which I think is more than reasonable. Might part out if enough interest.
Will sell for $5200 without LED lightbar, Bullbar and winch.
PM me if interested.
Author:  Docka83 [ Sun Nov 17, 2013 5:01 pm ]
Post subject:  Re: FS: 2006 M18A VVT auto Jimny
UPDATED post and pics. Must sell.
Author:  Docka83 [ Mon May 19, 2014 5:05 pm ]
Post subject:  Re: FS: 2006 M18A VVT auto Jimny - Must Sell
Author:  Poz93 [ Mon May 19, 2014 6:12 pm ]
Thats a well setup Jimny mate! Well setup for anyone looking for a touring rig! Good luck with the sale mate!
Author:  jake84 [ Mon May 19, 2014 8:19 pm ]
Great rig hope u find a new owner soon
Author:  jimbo_jones [ Mon May 19, 2014 9:34 pm ]
shame its auto thats a good price but im after a manual
Author:  Docka83 [ Thu May 22, 2014 5:48 pm ]
Bump....
Author:  jake84 [ Fri May 23, 2014 5:51 am ]
how much for the winch
Author:  Docka83 [ Sun Jun 08, 2014 8:51 am ]
$5500 - might have head gasket problem pressurising the cooling system but not 100% sure.
Just sitting here..... Want it gone.
Author:  Lukeszook [ Sun Jun 08, 2014 10:40 pm ]
How much would you want with RWC?
Author:  Docka83 [ Mon Jun 09, 2014 3:57 pm ]
Selling it as it mate.
Drives fine, just gets a cooling pressure problem when driving on highway for extended periods.
Author:  zukenutter [ Tue Jun 10, 2014 8:37 pm ]
I may come and have a look in a week or so if you haven't sold it.
Author:  jimbo_jones [ Tue Jun 10, 2014 10:34 pm ]
is that $5500 as it sits in the photo's?
Author:  Docka83 [ Wed Jun 11, 2014 6:44 pm ]
No worries mate!!
Yeah mate less the plates lol. Just need to put back seats/carpet back in.
As I'm getting a fair bit of interest can anyone who is interested please SMS me on 0410 496 053.
Author:  zukenutter [ Wed Jun 11, 2014 9:01 pm ]
I'll contact you Friday week if you haven't sold it. Good luck in the meantime.
Author:  Docka83 [ Mon Jun 16, 2014 7:14 pm ]
Bump!
Author:  Docka83 [ Wed Jul 16, 2014 9:42 am ]
Bump!
$5000 as is or,
$4500 minus the LED lightbar and UHF
Author:  atari4x4 [ Wed Jul 16, 2014 5:59 pm ]
fark, that's cheap!!!!!
hopefully you land yourself a job soon cause that's almost giving it away. :(
Author:  DUKE [ Wed Jul 16, 2014 6:44 pm ]
ill buy it for 5 grand as is mate, when can I pick it up ?
Author:  henno [ Wed Jul 16, 2014 6:47 pm ]
"Joined: Tue Jul 15, 2014 11:24 "
Straight on it ;)
Author:  atari4x4 [ Wed Jul 16, 2014 6:52 pm ]
has QLD plates, profiles says he's in QLD so I guess it's going to be a long drive to QLD from WA & back.
Author:  DUKE [ Wed Jul 16, 2014 6:57 pm ]
love driving, fly in drive back
Author:  atari4x4 [ Wed Jul 16, 2014 7:00 pm ]
get onto it, it looks like a bloody good buy... flights are cheap, probably would be able to sell it in WA for $15k. :rofl:
Author:  DUKE [ Wed Jul 16, 2014 7:00 pm ]
joined yesterday guys, only browsed a bit to check out this forum.
I have the xl-7 but this would be a great toy for daytrips.
Author:  DUKE [ Wed Jul 16, 2014 7:02 pm ]
won't be selling that in a hurry LOL, will enjoy that myself
Author:  Docka83 [ Wed Jul 16, 2014 7:35 pm ]
Wouldnt be driving it great distances as it still has the cooling system pressurising problem hence the price. I think its headgasket but the only way to confirm 100% is to pull the head off.
A low km M13a VTT is only $700-800.
Author:  zukenutter [ Wed Jul 16, 2014 9:29 pm ]
Someone buy it, everything is there, just needs some finishing, or as docka said, a swap back to 1.3. Whatever the case it's good value at this price.
Author:  DUKE [ Wed Jul 16, 2014 9:42 pm ]
I'll come get it on a car trailer if I have to, might have to as you are keeping the plates.
Author:  Docka83 [ Thu Jul 17, 2014 4:24 pm ]
Still for sale.
Author:  Docka83 [ Sun Jul 20, 2014 8:38 pm ]
Bump...
Page 1 of 2 All times are UTC + 9:30 hours
