It is currently Thu Nov 05, 2026 3:31 am
Post Posted: Sun Nov 17, 2013 8:24 pm
all items are pickup only and all prices are ono
1. lwb sierra chassi, suspension mounts cut off and front of chassis cut off infront of engine mounts FREE!!!!!
2. vitara power steering setup, includes pump, box, lines, pitman arm and 2 resoviors. $200
3. 3.7 ring and pinion. $30
4. vitara transfer case. $150
5. 2 sets of standard cv's and axels for a WT. $50 each set.
6. 2x 3.7 front diff centers. $100 each
7. wt rear diff center with auto locker and vitara 5.12 gears. (will fit front with 26 spline chromo axels) $250
8. wt rear diff center with auto locker and vitara 5.12 gears. has a tooth missing from crown wheel but has never had a problem in the last 4 yrs its been in the fron diff of a car. (will fit front with 26 spline chromo axels)
$200
9. sierra transfer case with 4wd switch, may need rebuild. $150
10. 33/10.5r15 bfg KM2's good tread, few cuts from 4wding but nothing too bad. $1200 set of 4
1
2
3
4
5
6
7
8
9
10
Users browsing this forum: No registered users and 156 guests
