It is currently Sun Nov 15, 2026 5:50 am
Post Posted: Sun Jan 05, 2014 3:23 pm
[*]Been having a bit of a cleanup and have a few bits to sell, there will be more to come as I go through everything. Ive decided to use 5.12 gears so I have a few 4.6 diffs and an extra power steer setup I no longer need. I'd prefer not to post as they are heavy and awkward to send.
2 x Vitara Rear 3rds - 4.6 ratio $150ea (sold)
1x Vitara Front 3rd - 4.6 ratio $150
1x 4.6 crown wheel and pinion $80 (sold)
1x complete vitara power steer setup (steering box, hard lines, res and pump $200
1x SWB Sierra Tow Bar $120
1x sierra 'just cruizin' body lift kit 2" - opened but never used $100 SOLD
As stated above, pickup only preferred. Items are located in Berwick, VIC
Post Posted: Mon Jan 06, 2014 2:33 pm
The 4.6 crown and pinion is that for a front or rear?
Post Posted: Mon Jan 06, 2014 3:02 pm
It was for a front. Its been spoken for now, I've updated the list up the top.
Post Posted: Tue Jan 07, 2014 2:34 pm
Pm sent :)
Post Posted: Tue Jan 14, 2014 12:55 pm
Bump! Will take offers. I've also got a complete 1l rear diff drum to drum, and a front 1l housing/centre/cv's (condition of the diff centres is unknown but may be of use to someone)
Vehicle: 1991 Vitara SWB
Post Posted: Tue Jan 14, 2014 1:32 pm
Whats the lift made out of?
Post Posted: Tue Jan 14, 2014 1:51 pm
It's a poly body lift. I think the correct name for the material is UHMW
Post Posted: Sat Jan 18, 2014 5:22 pm
Sorry bud, I misread. Thought it was a vitara body lift.
Vehicle: 92 Sierra hardtop
Post Posted: Mon Jan 20, 2014 8:35 pm
hey mate is the power steer setup complete for a sierra or what else do you need just the adapter kit?? :)
Post Posted: Mon Jan 20, 2014 9:12 pm
The steering box, lines, pump and reservoir is all there, all you need is the adapter kit like what BenT makes and it will all bolt in. I should have a set of multi rib pullies here too that will suit it if you need them.
Post Posted: Mon Feb 03, 2014 7:30 pm
bump, make an offer
Post Posted: Tue Feb 04, 2014 5:44 pm
Also have a roll bar here, mounts to wheel tubs. - $100 pickup only
pretty sure its made from 40nb pipe.
Post Posted: Mon Feb 10, 2014 4:25 pm
Also have a set of 4x mud buster flares ( http://www.mymudbusters.com )
I've done a BIG guard chop to make my car lower and run bigger tyres so these no longer fit. They mount to the stock flare brackets and are secured with plastic 'scrivets'. Probably the best looking aftermarket flare to suit a suzuki. One has a scuff mark on the top but otherwise they're all in good conditions. These won't explode or break like bushwhacker flares.
Chasing $350 ono for the set
Post Posted: Wed Feb 12, 2014 7:19 pm
You have a pm
Vehicle: 85 leaf suzuki sierra soft top
Post Posted: Sat Apr 05, 2014 8:28 am
tow bar still for sale?
Post Posted: Sat Apr 05, 2014 12:43 pm
yep tow bar is still here, send me a pm if you want it.
Vehicle: MG410 Gypsy
Post Posted: Mon Apr 07, 2014 7:31 am
Power steering still for sale?
Post Posted: Mon Apr 07, 2014 5:32 pm
Pm sent.
Users browsing this forum: No registered users and 11 guests
