Got this swb chassis here in good order $50 for bare chassis
Stockman rear cab panel with window, i have now cut this out, i have cut thru the pillars so the whole section can be removed via the spotwelds, i have cut across the bottom about 100mm above the rust line, perfect for a rear cab chop $40
stockman 16" wheels and tyres (tyres are very old) $50 the lot
also got a 1 litre transfer with switch $100 turns over but never drove it nt diffs 3.9 $80ea 1 litre 4.11 diffs $50ea 1 litre motor low compression $100
basically bits left over from the ute i wrecked, chassis is gone but i have the dash, column, steering box, jackshaft, front driveshaft, hubs, complete wiring loom etc
0419021757
