It is currently Fri Nov 06, 2026 1:31 am
Vehicle: '81 TinTop,32's,G13B,Crawlrs
Post Posted: Mon Feb 03, 2014 8:12 pm
I haven't been on this site for many months. These parts are still for sale and i'm keen to move. See revised prices below.
I've recently done a Hilux diff conversion and am getting rid of my old setup.
Front WT diff SPOA setup for NT chassis
4.6 ratio (I think its vitara centre?)
New swivel hub kit 18 months ago.
I believe it has a Piranha high steer kit on it.
Bash plate reinforcement to pumpkin
Good brakes and disks with extended brake lines.
Aloy bump stop spacers x2
Taper leaf, plastic bushed quality aftermarket front leafs
ARB Air locker fitted by Piranha in July 2012. My cars a trailer queen and have done less than 300km in the car since it was fitted (that's total, locker on max 20% of the time). I blew the rear diff on my second outing after the locker and diff rebuild. Cars been off the road over 12 months doing hilux drive train. Have receipt from Piranha for $962 for locker. They fitted it. They told me it was the first of the new style ARB lockers that they'd fitted before, weather that means anything to anyone.
$1000 ONO
Rear WT diff housing SPUA for WT chassis (had SPOA NT spacing but got damaged - never got round to changing this one)
4.6 ratio - gears are badly damage on pinion and crown wheel.
2 x axles
ARB air locker fitted - however condition unknown. Appears both axles are locked, regardless of air supply. Haven looked beyond this.
$250. Centre only SOLD pending payment. Housing and axles still for sale $50
Disk rear end setup
Toyota callipers - new brake pads
2 x rotors - one has a few gouges on the inside, otherwise good and true.
Steel brackets, spacers and brake lines ready to hook up to standard diff.
$100
Rear aftermarket leaf springs.
2inch lift from memory but I can guarantee.
$100
Webber 32/36 to suit 1.3lt
Redline adaptor plate
Accelerator bracket (I think I have the cable somewhere)
Ran a treat before I went injected motor.
$150
81 Sierra steering column and wheel
Missing plastic covers. All levers work well.
$20
Will contemplate a swap/part trade for 6.5 gearset or transfer case. I've damaged one of my gears and suspect I cant buy them individually :(
Items are located in Bayswater, Vic.
Mick on 0425731853 after 6pm preferred.
Users browsing this forum: Google Adsense [Bot] and 77 guests
