It is currently Fri Nov 13, 2026 4:19 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Post Posted: Sat Feb 08, 2014 2:29 pm
Please have a read. Need to make way for the GV axle kits.
viewtopic.php?f=15&t=44954
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Sat Feb 08, 2014 11:41 pm
If they sell out. Will there still be production if required?
Cheers, cal
Vehicle: Daisy
Post Posted: Sun Feb 09, 2014 5:52 pm
I had a look at the link Joe, since I have the Sierra kit with the vw calipers, does that mean I would need 16" rims? I haven't fitted them yet to test and there was no mention of that before, if that's the case though there's quite a problem for me.
Post Posted: Sun Feb 09, 2014 6:40 pm
If you bought the same kit as me, it will fit a 15" rim nicely
Vehicle: Daisy
Post Posted: Mon Feb 10, 2014 5:48 am
I hope so. I will have to put them together soon to check.
Post Posted: Tue Feb 18, 2014 11:55 am
Cheers, cal
I have to start concentrating on the Jim fronts and GV rears so I don't plan on doing rear Sierra or Jimny for quite a while.
Post Posted: Tue Feb 18, 2014 5:11 pm
Jimny fronts sound good. Ill have to wait a while as i need a lift kit as i went and welded on ora diff braces and forgot about it hitting the sump -.- so if it goes, it goes sadly. For now ill collect parts :)
Post Posted: Sat Feb 22, 2014 2:45 pm
Only Sierra axles left. Jimny sold out Armsup
Post Posted: Sat Feb 22, 2014 5:07 pm
#richjimnyowners
Post Posted: Sat Feb 22, 2014 7:22 pm
#poorsierraowners
#noonemakesanythingforLJs
Post Posted: Sun Feb 23, 2014 8:50 am
#givemedimensionsandiwill
Post Posted: Sun Feb 23, 2014 8:58 am
#bloodyhashtagsmakingithardtoreadshit
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Feb 23, 2014 9:46 am
#ibetjoecanreadthisfinecauseiwroteboobsinit
Post Posted: Sun Feb 23, 2014 12:17 pm
:rofl: Armsup
Post Posted: Sun Feb 23, 2014 12:40 pm
#mmmmmmboooooobs
Post Posted: Sun Feb 23, 2014 2:15 pm
Joe wrote:
# :rofl: Armsup
#fixeditforyouJoe
Vehicle: Daisy
Post Posted: Mon Feb 24, 2014 5:18 am
Do you have instructions available anywhere for the sierra kits anymore? I had an old set, I basically had to guess the orientation of one of the plates from the GV picture in the jml thread. Also as far as I can tell from test fitting, the stock 15" sierra rims foul on the passat calipers but 15" sunnys don't.
Any help joeblow? I'm guessing the large hole in the outermost plate mounts to the top and is for abs which isn't a problem, and that the handbrake cable holder that mounts on the caliper being slightly different to the stock holder means that the actuator lever needs to be taken off and moved a couple of splines?
Post Posted: Mon Feb 24, 2014 8:59 am
I'll be in the shed this arvo and will take some pics of the one I have on the Jimny.
Vehicle: Daisy
Post Posted: Tue Feb 25, 2014 5:30 am
Cool as, I figured it was essentially the same as the kit I do have your old instructions for, but given how important these are to get right I don't want to find out I'd managed to put it together backwards or something and it breaks while driving.
Post Posted: Thu Apr 03, 2014 12:47 pm
Two Sierra kits left.........
Post Posted: Thu Apr 03, 2014 1:58 pm
Joe. Still waiting for a response to the emails I have sent you.
Vehicle: Daisy
Post Posted: Thu Apr 03, 2014 7:51 pm
I should have updated this and said that I figured out what orientation the plates should be in and put the 10mmish hole at the top front as I guessed that it's for the abs sensor which I don't have or need.
Also the old instructions I had for the kit with pintara calipers said to put gasket silicone between the spindle and the plates, I figured this still let crap get in around the rear of the plates so I also put a little between the plates ad the diff tube, I know there's an axle seal there but if it never has to see any water then that's better again isn't it.
If anyone wants pictures of how I installed the kit let me know.
Vehicle: Swb sierra, Drover ute.
Post Posted: Sun Apr 06, 2014 9:32 pm
Joe I sent a pm. I want sierra ones if any left..
Post Posted: Mon Apr 07, 2014 8:50 am
I would like to know what seals have been used for this kit so I can buy replacements if necessary.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Apr 07, 2014 9:49 pm
the seals that came with my non abs kit are TC 30x62x8
TYO oil seal
other numbers on the packet are 400723N and a barcode 9324439177333
Post Posted: Tue Apr 08, 2014 8:17 am
Thanks
Just a note on the handbrake cables. As an interim measure to get the handbrake functional, as I do not have welder suitable to weld the thick steel of the caliper brackets, I removed the centralising bracket under the hump and drilled a hole toward the back, allowing this bracket to move forward 25mm. This allowed connection. I will need to severely shorten the caliper brackets as the LHS was resting against the exhaust. I have zip tied it to the radius arm until I am able to sort this.
I will investigate weather I can drill a hole toward the front of the centralising bracket to move it backward and take up the extra slack.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Apr 08, 2014 12:09 pm
would you mind taking a pic? i havent seen how the handbrake was meant to work yet, and im trying to confirm my calipers are right for the job
Vehicle: Daisy
Post Posted: Tue Apr 08, 2014 5:06 pm
Which calipers do you have, Joe had a couple of different kits available, this was the issue we had, expected pintara kits, got mitsubishi, couldn't find the mitsubishi galant calipers around here, Joe sent me a new set of plates to suit the VW passat calipers, which are fine unless you want to run rims with no offset in which case you would need 16" rims. If you're talking Jimny you need 16" rims for the passat version anyway.
I would have to go and check my rig to see how the calipers expect the handbrake to work, I haven't even looked at actually putting a handbrake into it yet I'm still waiting for my hubs to come back with fresh bearing races pressed in.
Joe do we require anything different handbrake wise for each kit? I remember reading something about needing a galant handbrake for the galant kit and pintara handbrake for the pintara kit, do I need to source a passat handbrake for the passat kit or was it a Jimny handbrake that suits it?
Post Posted: Tue Apr 08, 2014 7:14 pm
I'm using The Galant calipers. Also, The handbrake cable bracket fowls on the radius arms so they can't stay like this. To clarify, when I said 'weld the thick still of the caliper brakets', I actually meant the handbrake brackets bolted to the caliper.
Today I bought a cheap spanner set and ground down the 14mm to make it easier to undo the nuts securing the centralising bracket.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Apr 08, 2014 10:09 pm
nissan full float kit, have procured pintara station-wagon callipers (i think), which i have been told by a few people now are the same as a r31 skyline rear.
just trying to get a photo of what people have used and decide if what i have is viable, or if i need to go try and get my money back and go on the hunt again.
pics of what i have
Users browsing this forum: No registered users and 28 guests
