It is currently Sat Nov 14, 2026 4:08 am
Post Posted: Thu Jan 09, 2014 6:27 am
SWB SIERRA PROJECT $3000 ono
Regretful and forced sale, my 1995 SWB Sierra project which has all the right mods not to mention plenty of spare parts. Getting married soon, so it all needs to go. Specs are:
1995 WT SWB Sierra with only 120,000 on the clock! Rust free body and chassis, just needs the front end paint to be finished (will even supply the paint), it has a basic backyard paint job in army green and with a couple of hours work it will come up a treat!
• Baleno engine conversion (inc plumbing, radiator, full stainless exhaust, extractors, wiring, gearbox, exedy clutch, engine mounts, modified air intake… a very neat conversion that cost big $$$) Needs to be wired up, fuel pumps, and thermos still required. This engine was used in the BBM Sierra so money was no issue (even has the Sidchrome shifter gear shifter for those that remember the truck)
• Modified 2in lift using CJ jeep springs, and rear sierra springs up front with LROR HD extended shackles. Awesome flex, all imported from the usa, and bolts on. Uses Vit rear shocks in the front, but will need your own rear shocks… $$$ spent importing this stuff, and it works better than any other bolt on kit I have seen
• 2in body lift
• ARB chopped down front bar (not fitted was mounted on the rear, will need minor mods to fit the front)
• Warn 6000lb winch (also not fitted)
• HD Transfer bash plate
• Basic homemade rear bar with swing away mount (needs to be fitted)
• Std Vit steel wheels with new Pirelli tyres x4 but has room for 33’s
• Second alternator bracket with 65a vit alternator
• TJ wrangler rear flares all round (with two spares as well)
• SAAS seats (need to be fitted, near bolt in, good quality ones not the Supercheap auto crap)
• SWB black soft-top (under a year old)
• wood grain steering wheel
• Transfer case with 6.5 ration crawler gears (never used)
• HD transfer case mounting cradle with roctoy ring (gears installed just needs to be bolted back together)
• Rear diff with Spartan Locker (brand new needs to be built)
• Custom front roll hoop with mounts for an LED lightbar
Car is able to be moved and will roll onto a trailer, I can assist with putting it on the trailer too
SPARES: Boxes of lights, lenses, door rubbers, various 3.7 ratio diff gears, Spare rear tailshafts, Vit efi fuel tank, 2 radiators, air filter housing, Toyota 75 series power steering box modified to fit sierra, SWB fibreglass rear hardtop (needs work), STD WT sierra flares (red), 60L Vit fuel tank as well as the standard one
Prob much more I can’t remember… would only take a couple of weekends to get this thing running. All the hard work is done, and I have pretty much everything you will need to get her running again. I’m extremely bummed out about getting rid of it, I had big plans of doing the cape in this. Would love to see it go on to someone who will treat this Zook the way it should be… with utter disrespect haha.
Either finish it off, or take the good bits off it for your own Sierra and use the rust free panels as spares. Or build it into this….
LWB SIERRA PROJECT $500
Also, I have a LWB Sierra project that would be awesome if you built using the bits from the SWB.
The body is really quite straight and rust free, with only a small and easily repaired patch on the firewall near the booster. Comes with doors, front clip, dash, removable hardtop rear, bikini top front.
The chassis has been modified to take a Corolla engine, and some suspension mounts have been chopped off as this was going to get 4-linked. Easy fix for someone. YOU WILL NEED TO BE ABLE TO LIFT THIS SO BRING A FEW MATES... I'm happy to help where possible!
All items pick up from Sydney
Genuine buyers please PM me for more details, pics will be uploaded later today.
Evan
Post Posted: Sat Jan 11, 2014 8:31 am
Bump... need this stuff gone. Open to offers but nothing silly. Also happy to take away gear to bring the price down.
cheers
Ev
Vehicle: Vit swb 95
Post Posted: Thu Feb 13, 2014 6:19 pm
Hey man. Can you pm pics of both?
Post Posted: Sun Feb 16, 2014 1:28 pm
Can you send me some pics of the lwb?
Vehicle: Sierra LWB Hilux Diffs
Post Posted: Sat Aug 09, 2014 9:11 pm
Hi... is your LWB still for sale and can you PM me some pics if so... cheers
