Hey guys, My gti motor spun it's timing belt and smashed a few valves so I replaced it with a g16b instead so have no use for this. Basically it's everything you need to put in a gti motor minus the long motor and a fuel pump You get:
Mk1 gti dizzy and angle drive adaptor so no firewall cutting.
Rear thermostat housing and radiator hose.
Mk1 intake manifold with injectors,tps,and throttle body.
Custom extractors
Mk1 gti ecu with modified wiring loom to suit sierra all labeled.
Ran sweet in the car,no electrical problems at all.started cold and idled perfect.
Users browsing this forum: No registered users and 28 guests
