It is currently Fri Nov 06, 2026 9:03 am
Vehicle: 97 sierra
Post Posted: Thu May 01, 2014 1:59 pm
http://www.gumtree.com.au/s-ad/campbell ... 65?ref=ais
Engine:
Swift GTI G13B full rebuild, all seals replaced, head gasket, rings etc, proof will be provided. (approx. 6 months ago) rebuild needed as engine was smoking and preferred a fresh engine
NGK blue spark plug leads
custom made extractors
Custom made snorkel/cold air intake chamber
heavy duty engine mounts
exedy heavy duty clutch replaced when conversion was done.
new custom made exhaust
bosch fuel pump
dual century batteries
Falcon 120AMP alternator
Body:
2 inch leaf spring lift on it currently
Rust appearing under windscreen, hasn't grown since, small surface rust spots here and there.. Nothing major, rust has been cut out of the floor pan and new material welded back in.
Spartan ratchet type locker installed in front, and rear to be installed, currently has locked diff installed in rear.
Transfer case has noisy bearing, but only recently started getting noisier, but new case is supplied.
all new wheel bearings supplied.
checkered plate interior trims.
16inch sunny's on Hercules trail diggers for the front, close to new 95% and rear is about 60%
Custom steel tubing bars rear and front with LED indicators.
13,000 pound winchmax winch, not a crappy chinese winch..
uniden UHF
SPARES:
4inch lift kit including shocks and springs
tough dog steering dampener
original engine, not blowing smoke or anything, running perfect when removed, only removed because GTI conversion was needed for more power.
and many more bits and bobs.
Victorian rego until may 29th, but will most likely be sold with NSW blueslip depending on buyer.
Suzuki sierra vitara 4x4 patrol landcruiser rover
$5500 with NSW registration, or $4500 without.
Users browsing this forum: Google Adsense [Bot] and 167 guests
