It is currently Fri Nov 13, 2026 6:07 pm
Vehicle: A shed full of pieces so far
Post Posted: Sat May 10, 2014 9:21 pm
Sierra stuff for sale located Toowoomba QLD
WT Diffs
Everything that acn be replaced has been replaced and has never even been under a car.
ARB RD208 air lockers with nitro 4.6 ring and pinions. Built by ARB Toowoomba with full master install kits.
Rock Assult Chromoly front axles and Lowrange offroad Silverback Chromoly rear axles and a spare calmini short side rear.
All bearings have been replaced and a swivel hub rebuild done aswell.
Warn hubs and hub stud upgrade.
New brake pads and rotors on the front and new shoes in the rear.
Breather fittings have also been tapped in.
They have 63mm wide spring perches on NT spacing as i was going to use them with YJ springs but they will work with sierra springs with some 5mm flat bar as packing between the spring and ubolts and spring plates to suit.
These are as good as it gets with sierra diffs short of a full float kit on the rear.
The pair $5000
Rancho RS5000 Shocks to suit 4" lift
2 front 2 rear Brand new
$350 the lot
Plastic Flares suit sierra
Brand new
$380
1L Master cylendar
New
$50
WT Diffs
Front complete $250
Rear Missing brakes $100
Std WT front axles
$50
Std front hubs
$50
Most of the stuff is in the pics but i will ad the stuff ive missed and anything else i find when i get a chance.
all reasonable offers considered
Vehicle: Sierra SJ50
Post Posted: Sun May 11, 2014 7:29 am
PM sent regarding engine.
Post Posted: Sun May 11, 2014 11:21 am
heres a pic of the flares
Geasable sierra unis
6 of $25 each
WT speedo drive gear and seals. new from suzistore
$50
Post Posted: Sun May 11, 2014 6:38 pm
pm sent about flares
Post Posted: Sun May 11, 2014 8:58 pm
Hi dose the rear carrier have the side gears in
Post Posted: Sun May 11, 2014 9:05 pm
Yep side gears are still in it
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon May 12, 2014 8:12 pm
Pm sent
Vehicle: 1995 suzuki sierra, 30's, Lift
Post Posted: Thu May 15, 2014 6:33 am
Pm sent
Post Posted: Thu May 15, 2014 11:34 pm
Pm sent
Post Posted: Fri May 16, 2014 2:56 pm
On sent
Post Posted: Sun May 18, 2014 6:45 pm
Updated
Vehicle: Witch one
Post Posted: Mon May 19, 2014 7:45 am
are the flairs wider then standard
Post Posted: Mon May 19, 2014 3:02 pm
The flares are about 95mm wide.
Post Posted: Wed Jun 04, 2014 6:48 am
Also have 4x staun internal beadlocks new in packaging to suit 16x7-9" rims. $700
Post Posted: Fri Aug 01, 2014 8:01 pm
Edited and bump
Users browsing this forum: No registered users and 21 guests
