It is currently Fri Nov 13, 2026 5:39 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
Post Posted: Mon Jul 07, 2014 5:56 am
Top
I was cleaning out the shed over the weekend and found a box full of sierra bits and bobs.
3 x G13/16 water manifold pipes in vgc.
1 x 1.3 jx dash cluster.
1 x 1.3 ja dash cluster (no tacho).
1 x 1.3 jx dash cluster for parts.
3 x NT wipers (pairs).
Pile of NT front shafts and an NT jackshaft.
Several WT door mirrors.
Bonnet cable.
2 x clutch cable.
2 x WT swb handbrake cable (handle to diff).
1.3 air cleaner housing.
WT rear brake shoes NEW. Part no. 1617 I think?
Multi rib pulley set (4 bolt) suit 1.3 with falcon alt.
1.3 fuel pump.
1.3 flywheel dust shield.
Plus other little bits I'll throw in as I find them.
$120 the lot.
No offers.... no postage.
Pick up only from Nambour Sunshine Coast.
PM please.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Jul 17, 2014 11:22 am
Top
Any plastic WT flares?
Post Posted: Sun Jul 20, 2014 8:55 am
Top
No flares here...
More stuff I found.
4 x sierra washer bottles.
1 x nt jack handle.
1 x wt jack handle.
4 x sierra 1.3 fuel pumps
5 x fuel pump push rods.
2 x sierra wt clocks.
1 x vit clock. Same as sierra, just swap the face.
1 x wt brake shoe adjuster.
4 x soft top rear hoop hinges.
1 x 1.3 clutch lever.
2 x tow hooks.
2 x soft top windscreen clamps.
1 x lh 92+ guard plug.
1 x pre 92 guard indicator.
1 x 1.3 transfer shifter.
1 x 1.3 transfer case rebuild gasket and seal kit, new in packet.
All these parts go with the stuff above for a total of $120.
Pick up from nambour on sunshine coast.
Post Posted: Mon Jul 21, 2014 3:21 pm
Top
Bump. Getting sick of looking at all this stuff.
Post Posted: Fri Jul 25, 2014 6:49 am
Top
Price drop... All the stuff listed above and more... now only $100.
Vehicle: 92 sj70 wide track
Post Posted: Mon Jul 28, 2014 6:54 pm
Top
Hey mate. You wouldn't happen to have a 1.3 sump pan or an 1.3 oil return line?
Post Posted: Tue Jul 29, 2014 8:04 am
Top
No sump or pickup tubes here.
1.3's never came with a turbo so if you want an oil return line you'll need to make it.
Vehicle: Suzuki Sierra
Post Posted: Tue Jul 29, 2014 8:52 am
Top
how much would you like, if you were going to separate, for the rebuild kit?
thanks
Post Posted: Wed Jul 30, 2014 7:28 am
Top
thanks
Gasket set.... $100 and you get ALL the other stuff free. :wink:
Post Posted: Sat Aug 02, 2014 11:56 am
Top
SOLD.
Users browsing this forum: No registered users and 13 guests
