It is currently Fri Nov 13, 2026 11:21 pm
Vehicle: zook
Post Posted: Thu Jul 24, 2014 3:59 pm
I have a bunch of stuff leftover from the G16B swap I did in my Jimny a couple of years ago that may be useful to someone
G16B Baleno intake manifold/throttle body with sensors $50
Power Steering Pump $50
AC compressor, no lines $20
60 amp Baleno alternator $30
G13BB fuel injectors x 4 and wiring harness. $30
G16B fuel rail. $20
G16B flywheel $20
Various pulleys and idlers including timing belt idler (30,000km),as per photo, offers
G13BB "widebody" starter motor $30
G13BB timing belt cover $20
G13BB/G16bIntake and exhaust gaskets $5
G16B crank angle sensor $20
G16B cam angle sensor housing only $5
G16B coolant temp manifold with temp sensor and thermostat $10
Oil pickup strainer and end fitting (would need to weld the rest of the tube in for a custom pickup) $10
or 2 cases of beer the lot :beer: (Little Creatures Pale + White Rabbit thank you)
Some parts are from the donor engine (109,000km) while the G13BB bits are parts I took of my old engine (233,000km) All in working condition as far as I am aware, no returns, no guarantees though.
If you think the price is too steep on anything please make a reasonable offer.
Prices do not include postage.
or pick up from Adelaide. PM for details.
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Thu Jul 24, 2014 10:48 pm
Is the ac and ps pff the jimny?
Vehicle: zook
Post Posted: Fri Jul 25, 2014 7:13 am
Both those bits are off the Baleno engine.
Vehicle: '92 Sierra
Post Posted: Mon Aug 10, 2015 10:47 am
I dont' suppose you have the bracket that mounts the PS pump to the engine? It's the only part I don't have for a full conversion.
Cheers,
John
Vehicle: zook
Post Posted: Mon Aug 10, 2015 12:23 pm
This is the bracketry I have left over. I think the PS pump mounts in the black steel part of this which is bolted to the cast aluminium bracket which holds the AC compressor.
This is off the Baleno engine which is a different setup to a G16B from a Vitara.
your call.
Vehicle: '92 Sierra
Post Posted: Mon Aug 10, 2015 7:45 pm
Thanks mate. Close but I don't think it will work with mine. That one must use the AC Compressor or a separate pulley to tension the belt. The bracket I need has an elongated radiused slot that enables tensioning of the belt. Thanks for posting the pics up though.
Vehicle: sidekick g16b engine
Post Posted: Fri Aug 04, 2017 2:43 am
is the baleno intake still available for sell???
Users browsing this forum: No registered users and 19 guests
