It is currently Fri Nov 13, 2026 6:07 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
Post Posted: Tue Aug 26, 2014 6:10 pm
Top
Item: 1986 Suzuki Sierra LWB - trayback with extra-cab
Item Condition: Used
Reason for selling: Not used/Personal reasons
Price and price conditions: $7500 as is - $8500 fixed up (see below) - Prices are relatively firm.
Extra Info:
Pros:
-1.6L G16B EFI
-Vitara 60L fuel tank
-6.5:1 t-case w/ roctoy ring
-Power Steer w/ braced tie-rod
-NT to WT Conversion
-9500lb/4300Kg Aldi Winch w/ Synthetic Rope
-4-wheel disc brake
-Cro-mo cv's & axles
-Twin ARB Air Lockers
-32" Summit Mud Terrain on 16" XL7 Rims
-Custom Extra Cab
- coily dash & cluster
- Maruti Fibreglass removable roof
- MR2 Seats (very comfortable)
-Rock Sliders & tube Bar
-Virtual Lift
-1" body Lift
-Endless Air Compressor Set Up
-Dual battery Ready(ish)
-Stereo w/ 2-6" speakers & 2-6x9's
-Custom Tube tray
- Air Tank mounted under tray
- Air hoses to either side of tray with fittings (for pumping up tires/using sir tools)
- Second Battery tray for dual battery set up
- Timber bed
-RUF & 50mm raised rear springs all around
-Metric shitload of spares to go with sale
-Everything except tires is plated
-Registered until November & will assist with transfer
Cons: As mentioned above, many of these items will be fixed if purchased for $8500 (Deposit must be made)
-Custom Solid mount on the single mounted side of the t-case needs larger bolt & stronger/thicker washer
-Air-hose from compressor to tank needs to be replaced with Braided hose as the air-hose in it keeps splitting
-Springs need 2 leaves taken out of them - once this is done, U-bolts will need replacing (U-bolts supplied of brought as-is)
-Front Shackles need replacing
-Needs new bushes
-Switches on top of gearbox need to be switched around so the reverse light will light up
-Front air locker won't disengage - Believe it's just the plastic piston internally that needs to be replaced, as these commonly break off (if sold as is, I will pull the airlocked center and put a spare 3.7 I have here in it, so that you can wheel it until you fix the airlocker)
-Scratches on rims & minor panel damage/scratches
Contact: Please PM - I'm on daily
Pictures:
Build thread - Starts on page 2, not my build http://www.auszookers.com/forum/viewtopic.php?f=4&t=29224&start=30
Post Posted: Tue Aug 26, 2014 6:24 pm
Top
ohh noo.. selling the beast, definately a great car offroad.. good luck with the sale bud
Post Posted: Tue Aug 26, 2014 6:27 pm
Top
It's going to waste sitting in my garage, owned it nearly a year and only had it offroad about 5 times. Would rather see someone else get use out of it.
Post Posted: Thu Aug 28, 2014 9:02 am
Top
...I sent you a PM....might be what I am after with a bit more negotiation...... :)
Post Posted: Thu Aug 28, 2014 10:11 am
Top
Pm replied.
Post Posted: Sun Aug 31, 2014 5:08 pm
Top
Deposit Taken
Post Posted: Tue Sep 09, 2014 6:39 pm
Top
following, very interested!
Post Posted: Sat Sep 20, 2014 7:32 pm
Top
SOLD!
Users browsing this forum: No registered users and 21 guests
