Page 1 of 1
[ 2 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
dean_026
Vehicle: 96 SJ80
 Posted: Wed Dec 03, 2014 6:46 pm |
Up for sale is my Suzuki Sierra, it's been my project for the last 12 months and is almost finished and ready for rego, I'm selling because I no longer have the time or a suitable area to work on it, and will need a bigger 4x4 when I go away for work next year
Located Brisbane north west
Contact me by pm or on 0422620087 Asking $3500 as is no rego or rwc.
The modifications it has are G16b efi engine conversion from a vitara (mod plated) Wide Track transfer case with 5.14:1 reduction gears Bigger new alloy radiator & thermo fan 110 amp falcon alternator conversion Dual battery system with redarc solenoid HID spotties Custom snorkel Custom front and rear bar work 30 inch all terrains 2 inch suspension lift (coil springs) 12v power outlets in the back Bucket seats (mod plated) Fibreglass canopy (rare) Front & Rear recovery points
The engine has been fully rebuilt including the cylinder head being reconditioned, all seals and gaskets replaced, new timing belt kit and water pump, brand new fuel pump, it's got a new exedy clutch and a low km gearbox, new starter motor, injectors were professionally cleaned also. Will come with a few spare parts I have lying around for it. It needs a bit of tidying up interior wise, there is also some minor rust spots in the back below the flares, (probably not a rwc issue) and the engine seems to be idling quite high when cold, could be iac valve but not sure, it has a brand new starting battery but needs a new accessories battery, the exhaust needs a tail pipe, I've tried to describe it the best I can if you're interested you're better off coming and having a look yourself.
dean_026
Vehicle: 96 SJ80
 Posted: Wed Dec 03, 2014 6:48 pm |
Page 1 of 1
[ 2 posts ] |
