It is currently Sat Nov 14, 2026 3:07 am
Vehicle: A shed full of pieces so far
Post Posted: Sun Feb 15, 2015 9:30 pm
G16b with aw4 auto with loom and computers, shifter, vitara dash cluster, viscous fan, sierra sump and oil pick up, extractors and in tank fuel pump.
The following are new parts. Some have been fitted.
Trail tough auto to sierra adaptor kit including bolt in crossmember, un breakable trans mount and preformed weld in plates to widen the trans tunnel. The bush and seal has been installed to the output of the transmission to take a shortened sierra jack shaft (not included)
Trail tough unbreakable engine mounts.
Spal thermo fan
Vitara radiator
Vitara throttle cable
Exhaust gsk
Oil cap
Sump gsk
Custom 1 Litre swirl pot
VL efi fuel pump
Facet lift pump
The loom has been partially stripped out but still includes the vitara dash.
This is pretty much everything needed to fit a g16b auto into a sierra.
$1800Ono
Located toowoomba qld
Post Posted: Tue Feb 17, 2015 8:26 am
Pics located here. http://pages.ebay.com/link/?nav=item.vi ... 1779818603
Vehicle: 97 Sierra
Post Posted: Thu Feb 19, 2015 9:08 pm
Will you sell them engine only..
If do how much?
Vehicle: Tin Top
Post Posted: Fri Feb 20, 2015 6:35 am
Preformed weld in plates for the transmission tunnel, would you sell them seperate and or where did you get them?
Post Posted: Fri Feb 20, 2015 7:38 am
Trail tough sell them as part of the auto install kit.
LROR sell them too
I Wouldn't think separating the kit would be wise
Post Posted: Fri Feb 20, 2015 9:43 pm
Yeah the panels come with the auto kit. I'd rather not part it out at this point. It took a long time to gather all this stuff.
Vehicle: 1999 jimny
Post Posted: Fri Feb 27, 2015 2:41 pm
I will take the aw4 transmission, trans computer, torque converter and flex plate if you want to split it up.
Post Posted: Tue Mar 03, 2015 7:36 am
Price drop
Post Posted: Fri Apr 10, 2015 3:18 pm
Price drop. Will consider splitting it up.
Also have a bolt on pan hard kit for spoa sierra. $250
Vehicle: Tin Top
Post Posted: Fri Apr 10, 2015 9:16 pm
Price on Trail Tough Auto adaptor kit if you seperate ?
Post Posted: Sat Apr 11, 2015 10:13 am
$150. It won't have the rear bush or seal for the trans as its already installed and I don't want to risk damaging it
Post Posted: Sat Apr 11, 2015 3:10 pm
How much for auto and all associated parts for Sierra?
Post Posted: Sun Apr 12, 2015 5:59 pm
Auto is gone. Will get individual pics and prices up tomorrow night. Pm what bits you want.
Users browsing this forum: No registered users and 13 guests
