It is currently Fri Nov 13, 2026 9:06 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Vehicle: Vitara 1990 SWB Soft Top
Post Posted: Sun Apr 19, 2015 9:54 pm
**** Update... All left over parts including Body and Chassis and rolling gear going to tip Sat 22/8...
**** UPDATE.... IM DONE WITH THE DONER CAR> Everything must go... If any one wants the wreck and all left over bits make me an offer :)
So here's the deal. Picked up a t'boned 16B as a donor car for my Project. Obviously a lot of bits i will be using (thats why i bought it :) )
I will be swapping the EFI into my Project so the 16A is up for grabs along with gearbox and lots of other goodies.
I'm not prepared to pull out all running gear just yet as I need to be able to move it around etc.
The 16A had top end rebuilt just before i acquired it and runs nicely. Happy for you to see it running and do whatever test you need to be satisfied.
I want to swap the engines sooner rather than later so get in touch and make me an offer.
Most of the interior from done car I am keeping so theres lots of bits outta the old project that are in good working order but grubby.
Anyway... PM me with what you're after and lets see what deals can be done.
Bretski.
Some things that are avail now -
Guards, grill and bonnet of '90 Model
Passenger Door from the '96 Model
Door Glass
Windscreen ( You gotta remove it)
Soft Top... OK condition
G16A (Carbi Motor) and some ancillaries
Gearbox
Alternator
Mirrors
Radiator
Some Lights
Front Bumper and Frame from the '96 Model
Complete Dash
Instrument Cluster
Seats
Stuff that will be avail soon...
Power Steering Rack/Pump and all bits.
Standard Rims and Tyres
Diffs and running gear
Suspension parts
etc etc...
Post Posted: Mon Apr 20, 2015 3:16 pm
THE SOLD LIST...
Look here first before you message me asking for parts. If its in this list its gone... Don't waste yours or my time :)
____________________
- Drivers Side Mirror
- Engine
- Alternator
- Power Steering
- Starter
- Indicator/Wiper Stalks.
- Soft Top and Hardware
- Gearbox and Transfer
- Radiator Mounts
Vehicle: 89 SWB Sierra (soft top)
Post Posted: Tue Apr 21, 2015 9:01 pm
How much for the flywheel?
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Wed Apr 22, 2015 11:55 am
How much for the 16A motor
Post Posted: Wed Apr 22, 2015 6:32 pm
Its in really good nik.... so around $1k for the Motor + 5 Speed Gearbox and everything in-between Willing to negotiate. PM me your number an I'll call you to discuss and you can come and inspect it and see it running and do compression test etc if you want.
Post Posted: Wed Apr 22, 2015 6:33 pm
I'm thinking this should be a part of the motor since I'm selling it as a running package. I'll keep you posted.
Vehicle: Sierra
Post Posted: Thu Apr 23, 2015 6:49 pm
Was thinking this might be an easy swap for me if Bulldog 61 didn't want it but alas its out f my reach financially.
Post Posted: Sun Apr 26, 2015 6:22 pm
Everything is negotiable. Looking at doing engine swap next weekend. Keen for it to go...
Post Posted: Sun May 03, 2015 2:54 pm
Wouldn't happen to have a 5 bolt multirib crank pully would you??
Post Posted: Sun May 03, 2015 3:25 pm
I'll Check what it is. All pulls are ribbed but not sure of bolts. However I am reluctant to separate the engine parts at this stage as offering engine as whole and running
Will let you know.
Post Posted: Sun May 03, 2015 3:44 pm
Engine is out and available.
Compression tested all 180-190 PSI ... please be mindfull that my tester is old rubber seal type not screw in so its not super accurate but still gives good indication
See video of engine running here - :arrow: Engine Test
Post Posted: Mon May 04, 2015 9:19 am
Definitley grabbing the G16A and box mate, have sent you a PM
Post Posted: Mon May 04, 2015 9:23 am
Do you still have the power steering setup? and what are you chasing for it.
Post Posted: Mon May 04, 2015 10:43 am
Yes Power Steering is avail as well. But just might be a few weeks for some parts as I still need to be able to move the donor car. I've sent you a text.
Vehicle: suzuki vitara lwb
Post Posted: Tue May 12, 2015 5:39 pm
Just wondering if you had a exhaust manifold at all
Post Posted: Tue May 12, 2015 10:49 pm
Sorry Mate Gotta give that with the engine
Post Posted: Sat May 16, 2015 2:05 pm
Cv's?
Post Posted: Sun May 17, 2015 4:57 am
mrw82 wrote:
Cv's?
Yes thy will be available in a few weeks. Send me a message
Post Posted: Thu Jun 18, 2015 10:17 am
Someone messaged me re the 16B Fuel Tank but the message disappeared... If you want it its avail... I've decided to just use an inline fuel pump instead as my original tank is in better condition.
The tank is a bit crusty inside but solid and no leaks. Fuel pump and sender working but very crusty too. I'd put a new pump kit in for sure if i was to use it.
$150 or best offer...
Post Posted: Thu Jul 09, 2015 7:23 am
So I've pretty much taken everything i need now and everything else must go.
Heaps of stuff left including:-
Windscreen, Seats, Dash, Consols, Gearbox and Transfer, Soft Top, Suspension, Difs etc, Brakes etc, Headlights and Tail Lights, Fuel Tank (non EFI) loads more and the wreck itself. T'Boned on Drivers Side. All Passenger side panels ok.
Message me with what you want and make a reasonable offer and its yours.
Pick Up Brisbane North Side
Vehicle: Vitara 1.6
Post Posted: Thu Jul 09, 2015 9:54 pm
Not sure if you are willing to post stuff?
On the basis of keeping things small and easy to send...
- passenger side top radiator mount
- inside fuse-box cover
- front strut top covers
- indicator stalk or assy (whatever is easiest)
- steering column top cover (only if it looks good)
Post Posted: Sun Jul 12, 2015 1:04 pm
:) Radiator Mount Yes but from the G16A so it has the washer bottle mount.
:( Fuse Cover No
:) Strut upper mounts is that what you meant? If so yes
:) Indicator assembly Yep
:? Column covers are very average and brittle
Vehicle: 91 and 97 grand vitaras
Post Posted: Tue Jul 14, 2015 9:23 pm
Have you got the drivers side headlight surround the plastic clip on bit for the panel and will you post to wollongong area.?cheers
Here's a bowl full of dicks knock yourself out!
Post Posted: Wed Jul 15, 2015 8:57 am
The Grill and headlight surrounds are all one piece. I'd be happy to post... but its not small... not sure if thats what you're after?
Vehicle: Vitara 1.6
Post Posted: Fri Jul 17, 2015 10:46 pm
Ok so what condition is the indicator assy? And what do u want for if?
Mine is mostly ok but flicks out of high beam easily and does not always turn left indicator on. If it not in fantastic condition i will look to fix what i hav..
Post Posted: Sun Jul 19, 2015 5:55 pm
Its was all 100% working ... The printing on the stalks is pretty rubbed off but otherwise all working fine.
$30 (+ Postage if required) and its all yours. :peaceout:
Post Posted: Tue Aug 11, 2015 1:53 pm
If you want anything speak now or forever hold your :rofl:
Happy to GIVE AWAY the shell and Chassis Diffs etc...
Vehicle: '92 Sierra
Post Posted: Fri Aug 14, 2015 1:45 pm
Does the instrument cluster have the VSS if so is it for sale?
Vehicle: SJ80, SE416
Post Posted: Sat Aug 15, 2015 11:01 am
PM sent.
Vehicle: Which one?
Post Posted: Sat Aug 15, 2015 11:09 am
Reubs wrote:
PM sent.
Oh yeah, me too. Four or five days ago haha 8)
Users browsing this forum: Google [Bot] and 28 guests
