92 wide track, Drover grill Reco motor 14 tho k ago Trail tough reduction gears 114% low range 15% high range 30x9.5 muddies with 2000k on them Ome 2 in springs Extended shackles Extended brake lines Alloy bullbar Removable 2 piece glass canopy Custom roll cage
Has been used off road so it has some dents ECt has had the front panels replaced Included is 1 rear 3.9 diff as I was going to change them Also have original transfer case.
Users browsing this forum: No registered users and 24 guests
