It is currently Sat Nov 14, 2026 2:31 pm
Vehicle: Soft top Vitara, 3' lift, 30s
Post Posted: Sat Nov 07, 2015 8:22 pm
Twin Locked SWB Soft Top Vitara $2750 Neg
Up for sale my twin locked vitara 1990 carbi with about 275000ks located on the Gold Coast 4213. This Vitara will be sold with no rego and may need a few things fix up to do so, please see the ad below for details, any further questions please pm or text me 0423508660. If it cannot be sold whole I will be parting….Advertised else wear. Will post parts at buyers expense.
General Good; Seats are comfy and have useful seat covers, power steering, fairly new exedy clutch and cable, rubber mat in the back, LED reverse light on a two way switch (OFF, ON and ON with reverse), 4 point roll bar (only made from ally but looks good and better than no roll bar), stealth rock sliders, dint free fuel tank with bash guard, front bash plate, removable mud flaps and removable hard top over the front half of the cab. Will give all my spare parts with the car tail lights, trailing arms ect…….
General Bad; Soft top zipper only goes ¾ the way around, UHF is a bit touch n go, no rear seats exhaust is dinted up, body has a few dints and chassis is a bit banged up from rocks ect.
Under the hood:
The good; 1.6 Carbi with 2” extractors, Snorkel, has had rear main done and a front end seal kit with timing belt early this year. Newish radiator and the carbi was rebuilt by motorcarb a few years back runs like a dream.
The Bad; Rocker cover needs resealing as it leaks out the back a little and the window washer don’t work.
Drive line:
Gear box Syncs and Bearings replaced in 2013 (very nice tight box), brand new front wheel bearings where pressed in earlier this year.
Rear; 5.12 ratio diff, ARB Air locker with ARB compressor, LWB rear brakes.
Front; 5.12 Ratio diff, Lock right Auto locker, stub axel conversion with support bush so you only need one spare cv (drivers CV will go both sides), Manual locking hubs & 1 x spare.
Suspension: 2” King springs with “1 worth of spacers, camber bolts in the front struts. Commy shocks is the rear with extended bump stops, 2” A arm spacer and 12mm tail shaft spacer.
Wheels; 5 x 30x9.5R15 Federal M/Ts on Geko Sunnies 1 @ 80%, 2 @ 40%, 1 @ 25%, and 1 @ 10%
For pics look at gumtree or text me http://www.gumtree.com.au/s-ad/gold-coa ... osted=true
Users browsing this forum: No registered users and 14 guests
