It is currently Sat Nov 14, 2026 1:03 am
Vehicle: 1988 Suzuki Sierra SJ50
Post Posted: Sun Aug 02, 2015 6:25 pm
1988 Suzuki Sierra - Runs well, but not roadworthy.
Price $2000 for quick sale. Must be gone by the end of this weekend (Oct 2)
Pick up only. You will need to tow this as it is NOT DRIVEABLE
Location - Victoria, Carrum Downs.
PM me for address or more details.
Photos
https://goo.gl/photos/2T5Me7mynZSiGRGZ9
Additional Details
It has a 1.6L EFI G16A engine and a 1L surge tank under the hood. Its also had a significant suspension and body lift fitted to it (around 4 inches all up)
The engine and the front bucket seats are blue plated (Engineered/Approved in QLD). It has some surface rust in a few spots over the body, but all serious rust has already been repaired.
What I've done:
Replaced Shock absorbers
Replaced radiator with brand new honda civic radiator (with electric fan and shroud)
Installed rock slider to one side of the car (other side needs minor modifications as some lines interfere with the bolt on location)
Stripped, repaired and Painted the inner floor of the car with Rustbullet
Covered the entire inner floor of the car with Dynamat Xtreme
Replaced MDF door liners with Aluminium checkerplate
Replaced dash with custom made aluminium dash
Installed ECU inside the cabin, just under the dash.
Installed Amplifier for radio.
What needs to be done for roadworthy:
Fit flares to wheel arches (i have 4 x jeep flares)
Fit gauges to dash (I was going to get tablets and use a OBD2 link)
Install Seats
Reinstall handbrake cable
Reinstall windscreen wipers and steering wheel
What is included with the car:
2 sets of 4 wheels, (31" and standard)
2 Front bucket seats - have been fitted before
1 rear double bench seat - needs modification before fitting
Raptor ute-liner paint (i was going to paint the car floor with this)
All the parts which were removed from the car, except the plastic dash.
Post Posted: Mon Aug 03, 2015 9:45 am
Blue plate? What does that mean in Victoria?
Post Posted: Mon Aug 03, 2015 6:39 pm
It was blue plated in QLD. I really should have mentioned that somewhere.
In QLD It means the modification has been inspected and certified/approved.
Vehicle: Tin Top
Post Posted: Mon Aug 03, 2015 8:57 pm
Its only inspected and certified in Qld, no good for any other state.
Would need to be engineered again in any other state for a blue slip/road worthy, $$$$$$
Good luck with the sale :)
Post Posted: Mon Aug 03, 2015 9:23 pm
Maybe... but i'd need to check up to be certain... this thread seems to have divided opinions
http://www.aussiev8.com.au/legislation- ... d-car.html
worst case scenario, i'll just wreck the car... shouldn't be to hard to get a few grand still
Post Posted: Tue Aug 18, 2015 7:29 pm
1. What I'm selling
1988 Suzuki Sierra
Mechanically in great shape however its far from roadworthy. Needs time spent on it.
The engine and the front bucket seats are QLD Blue Plated. It has some surface rust in a few spots over the body, but all serious rust has already been repaired.
Since I've had the car I have done a fair bit of work to the beast, but I'm only about halfway finished and have lost interest.
What I've done:
Cut out rusted area below the windscreen and welded in new steel.
Replaced leaking radiator with brand new honda civic radiator (with electric fan and shroud)
Stripped the inner floor of the car to bare metal, welded up all the excess screw holes from 25 years of things being installed
Replaced warped dash with custom made aluminium dash
Removed faulty handbrake cable (still needs to be re-installed)
What still needs to be done for roadworthy: (disclaimer: this is my opinion):
Install Seats
Repair handbrake
A whole pile of parts that I pulled out of the car
Other Details
2. Location - Victoria, Carrum Downs.
3. Pick up only. You will need to tow this as it is NOT DRIVEABLE
4. Price - I want to start with $4000 ONO. At that price i will be losing around half of the money I have put into this car. (the custom dash was $1000 by itself)
5. If you can PM me, that would be great. I'll then PM you back with my mobile number and email. I can also give you my address if you want to come and have a look.
6. Photos
Click the following link to see a lot more photos
https://plus.google.com/+AshleyWaugh/posts/VHJWcm8svv5
Some photos from that selection are here:
Vehicle: MG410 Gypsy
Post Posted: Thu Aug 20, 2015 10:43 am
looks tidy, good luck.
what condition are the 31 tyres in how much tread is left?
Vehicle: sj80 2 inch body 40 mm suspens
Post Posted: Wed Aug 26, 2015 6:45 pm
wrecking yet? i would be interested in the 1.6efi and possibly complete front diff if its WT (if the price is right)
Post Posted: Wed Aug 26, 2015 6:53 pm
if you decide to part it out i would be interested in the 1.6efi and possibly complete front diff if its WT (if the price is right) and some other small bits a pieces! PM me or contact me on 0401034750, mobile prefered!
Post Posted: Wed Aug 26, 2015 8:37 pm
If you part it I'm keen on front clip.....
Users browsing this forum: No registered users and 9 guests
