It is currently Fri Nov 13, 2026 9:06 pm
Vehicle: '94 suzuki maruti
Post Posted: Wed Sep 16, 2015 5:57 pm
Parting my maruti after hitting a tree stump and bending the chassis/front diff. most other parts are available, few prices below, anything else just ask:
GTI engine conversion: $1500 sold
everything ready to drop in. includes exedy HD clutch (2500kms old), surge tank/lifter pump/bosch 070 EFI pump, ecu/wiring loom with everything labelled where to be connected, sump & pickup from a sierra, mazda cap/rotor, plugs and leads are 3k km old. has oil leaks but runs nicely. still in car to be heard running for now. basically ready to drop in and go. i'll include gearbox if wanted
front/rear airlocked 4.57 diffs & arb compressor: $2500 wont separate sold
lockers cost me $1000 each, gears were USD $190 each, bearing kits USD $100 each, labour was $1000 all up. these cost me over $4000. air compressor included air-up kit, and arb compressor/front/rear locker switches. note: pinion bolt pattern is to suit NT, but i'll include the part of the driveshaft necessary to make these straight fit if wanted.
Long range tank: $100 sold
i dont know what this will/wont fit but i suspect the mounts are custom, and it would only fit under a trayback. ~80L & has a dint in the bottom.
HD rear axles: $200 sold
lowrange offroad Heavy duty rear axles, these are $290 USD plus postage new and they've done less than 3000km since new
Vitara Front brake conversion for sierra: $200? no idea what this is actually worth?
includes LWB vitara calipers professionally rebuilt 18 months ago, 4" (100mm) extended brake lines, DBA T2 slotted rotors, Bendix 4wd pads. these have all done less than 10k kms.
4.16 Transfer case: $500
NT flanges but they're easy enough to change to suit wt. tip of the transfer stick snapped off inside, but i tested it and it all turns and shifts easily, you'll just need to get the tip out of the case, probably through the drain hole or something
i'll need to go through everything else to check for damage before i advertise more and i'll add to here as i think of stuff but feel free to ask about anything else. dont really want to post stuff but i will if wanted. build thread:
viewtopic.php?f=4&t=30375
Post Posted: Thu Sep 17, 2015 6:36 am
Still in Gracemere?
Post Posted: Thu Sep 17, 2015 6:46 am
Pm sent
Vehicle: Suzuki Sierra
Post Posted: Sat Sep 26, 2015 11:24 am
Is the 4.16 transfer case still for sale?
Post Posted: Sat Sep 26, 2015 7:32 pm
Still available, only things gone from the car are bullbar and sidesteps
Vehicle: Maruti Trayback
Post Posted: Tue Sep 29, 2015 8:25 am
pm sent
Post Posted: Thu Oct 01, 2015 5:18 pm
Hey mate, do you have the roof and back for sale?
Post Posted: Thu Oct 01, 2015 5:53 pm
Roof came off at some point while I was towing it home... Backs there but no roof sorry
Post Posted: Thu Oct 01, 2015 7:22 pm
Pm a price for the back please cheers
Post Posted: Sun Oct 04, 2015 11:25 am
i have no idea what these things are worth at all, but i'll be driving to brisbane sometime during the week starting 12th October so i can deliver it to save you on couriers, $450?? is that fair?
can also deliver parts anyone wants to anywhere between rockhampton to brisbane (a little further im willing to discuss) in the same week...
Vehicle: Sierra '90
Post Posted: Thu Oct 08, 2015 8:25 pm
would you be interested in posting ? the rear axles are wt ? also keen on transfer
Post Posted: Thu Oct 08, 2015 9:08 pm
Axles are sold pending payment, I'll let you know if it falls through for whatever reason.
Transfers still available, just Pm me your postcode if you want me to get a postage quote, unless your in Brisbane then I can deliver next week
Users browsing this forum: Google [Bot] and 28 guests
