It is currently Sat Nov 14, 2026 3:01 am
Vehicle: 92' 1.3l leaf sprung Sierra
Post Posted: Mon Jan 04, 2016 4:56 pm
For sale
Suzuki Sierra 'extremely modified'
Has too many upgrades to list ( close to $10k worth) but highlights are fully recon custom 1.3/1.6 engine from Suzistore with myside2 carb setup from zuks off-road. Ott anti sway setup, jk wrangler spoa kit, 6.5 crawler gears, locker in rear and much more....
Running 33" with close too 12" of lift overall and 1.5m articulation.
Was yellow stickered on the 1st. but has been driving as a daily for years (I think they were just bored)
Serious interest only and I WILL NOT BREAK!
$6k firm
Bunbury W.A
Drivable on road till the 10/1/2016
Post Posted: Mon Jan 04, 2016 4:59 pm
Engine
Sierra 1.3 top, vitara 1.6 bottom built by Suzistore Perth
Myside2 screaming eagle side draft Carby with water cooled manifold from zuksoffroad.com
Oversize Clutch fan and manual electric fan
New hoses and leads
New dizzy and coil
Extractors
New engine mounts
Exceedy extreme duty clutch
Oversize radiator
Rebuilt gear box
Rebuilt xfer case by lowrangeoffroad.com with crawler gears, held in place by a super snatch cradle from zuksoffroad.com
Driveshaft spacer and custom built rear driveshaft with double knuckle joint
Full bolt on 8" trailblazer Jk spoa from rocky-road.com with Ott steering upgrade and modified long travel 8000 shocks, front high bolt on shock brackets and back center mount bolt on points
Front diff is reinforced with weld on braces and bash plate
Rear diff has bolt on skid plate/brace, with arb air locker
50mm front and back wheel spacers
Steel 15" powdercoated rims with 33x 12.5 federal mud tires 75% front 15% rear
Extra wide bull bar with mean mother winch, new synthetic rope by bulvanties
Solid Rock sliders that go underbelly
Bushwacker guards
Led rear bar with tow bar and pull out points that bolt thru to the frame rails
Bucket seats with correct rails not bolted so can be adjusted.
Ridge rider led spotlights
Custom made roof rack with cage
Post Posted: Mon Jan 04, 2016 5:36 pm
For anyone interest, I can send photos either via email, text message or via Facebook
Post Posted: Tue Jan 05, 2016 1:15 pm
I'd be interested to see photos of this 1.5m of articulation, because from my calculations, it's basically impossible to achieve- there's less than 1.5m between the outside edge of the tyre and the inside edge of the opposite tyre, so 1.5m of articulation can't be achieved even with one axle vertical.
I don't even think this car has 1.5m of articulation.
Post Posted: Tue Jan 05, 2016 4:08 pm
Selling the good bits separate and returning the car to a liscenced less modified state will get you most $$$. Understand the car will never be able to be liscenced in w.a. with that susp setup will likely put alot of punters off
Post Posted: Tue Jan 05, 2016 7:50 pm
Maybe it's 1.5 metres if you measure the hypotenuse
Post Posted: Tue Jan 05, 2016 8:31 pm
Hmm maybe. I drew it out on cad. Looked pretty funny.
Post Posted: Thu Jan 07, 2016 8:29 pm
Any pics? I need to see it!
Post Posted: Fri Jan 15, 2016 3:09 am
[img]IMG_4347.jpeg[/img]
Post Posted: Fri Jan 15, 2016 3:10 am
How do you add a picture from a iPad/iphone
Post Posted: Fri Jan 15, 2016 7:06 am
Upload the pic to photobucket or similar.
Then paste the link here
Users browsing this forum: No registered users and 7 guests
