It is currently Fri Nov 13, 2026 9:37 pm
Post Posted: Fri Nov 27, 2015 12:20 pm
Getting rid of some stuff from old projects:
- Full floater 300M axle shafts, supplied by performance cryogenics (Kickass Off-road). These have never been fitted to a vehicle, plan has changed and aren’t required. Cut to length to be used in a Vit rear housing WT full floater conversion as described here: viewtopic.php?f=14&t=38240 . $700ono
- 4 x 31” Silverstone Extremes, about 70% tread. Will be just tyres, no rims $600.
- Front WT housing with Vitara rear centre section welded in. This is to run a Vit rear centre in the front of a WT, giving you the stronger centre while still running chromo cv’s. $100
- LWB Sierra Maruti body, white with a little rust but not bad. $100
- LT230 Rover transfer case with T700 adaptor. $600
- 98-05 GV Steel front diff with RD88 Airlocker and 5.12 gear set. Centre was rebuilt and installed by ARB when the locker was installed. Also comes with stubby shaft conversion so bolt on shafts work both sides. Great upgrade for either GV or Vitara $1200
- 16” Weld on beadlock kit from All Metal Magic. 5 sets of inner, outer and coning rings. $450
All parts located in Rockhampton, can post.
Users browsing this forum: No registered users and 27 guests
