It is currently Fri Nov 13, 2026 10:38 pm
Vehicle: 2018 DMAX
Post Posted: Thu Mar 31, 2016 3:50 pm
Sierra transfer with 6.5 gearset. Looks to have WT front outputs, drum hand brake rear that has been drilled with WT spacing. Rocktoy ring, welded to standard mounts. Approx. 500kms on it. Front output looks like it needs shimming. $500 SOLD
Baleno 1.6, right angle dizzy swap, custom grind cam shaft. Rebuilt head, block has roughly 150, 000 on it. Includes clutch. Put roughly 100ks on it after the head was rebuilt, then pulled and stored for the last 2 years. $500
I do have the loom and ECU for this somewhere in the shed, however the loom was cut and will need to be re joined. If you want it you can have it.
Sierra 5 speed gear box, pulled from the same vehicle as the above engine. $150
Sierra 5 speed, i think 2nd gear was a bit rough to get into.. $80
2' exhaust, with extractors to suit the engine above. single muffler, cat with no internals. $150
Located in Browns Plains, 4118.
You can contact me on here..
Pick up only
Vehicle: 91 sierra wt
Post Posted: Thu Mar 31, 2016 5:43 pm
Hey mate il take the transfer can pick up tonight
Have pmd you mate give me a call or text 0418649574
Cheers pat
Vehicle: 2018 DMAX
Post Posted: Fri Apr 01, 2016 4:01 pm
Transfer is sold..
Vehicle: 2018 DMAX
Post Posted: Thu Apr 07, 2016 1:29 pm
Second gearbox added.
Vehicle: 97 SJ80 Sierra
Post Posted: Tue Jun 14, 2016 5:19 pm
Baleno Engine still available?
Users browsing this forum: No registered users and 21 guests
