Joined: Tue Nov 23, 2010 8:01 am Posts: 323 Location: adelaide
Posted: Sat Oct 29, 2016 10:09 am
- Rego until 12/1/17 - Front sway bar removed for better articulation - Return to center stealing dampener - Electric fuel pump - Alloy radiator - 1.6L g16a (carby) Vitara motor 40 thou overbore and mild cam fitted with BenT adaptor kit - extractors with custom exhaust, hot dog resonator and muffler - Custom cast intake manifold ( Myside 2 kit) that moves the carby mount from a downdraft to a sauce draft - Harley Davidson screaming eagle 44mm side draft carby with choke - HD clutch, not to aggressive just a little nicer than stock - Safari snorkel (fitted to car but not plumed to the Carby) - Pod filter - Sound deadening been added and carpet in front foot wells - CD player - Soft top in good condition
Bad points - Snorkle needs to be plumed into intake - choke cable needs to be adjusted as it won't stay out on its own and needs to be held out, I have just been to lazy to do this - fuel gauge doesn't work, haven't looked into why
The body has some scratches and small dents, it is a 24 year old Sierra but overall is in great condition
